20 Most Recent Toshiba Satellite A15-S129 Notebook Questions & Answers
2answers
DVD Rom
try re-installing the device drivers to sort the problem
1/2/2020 8:41:09 AM • Toshiba... • Answered on Jan 02, 2020
2answers
My toshiba a15's cd/dvd rom can't read dvd's
The newer dvd's often won't play on older machines. The easiest solution is to download and install the VLC Media Player. The VLC Media Player is an open source free player and can be downloaded here.
Hope this solves the problem.
1/2/2020 8:38:31 AM • Toshiba... • Answered on Jan 02, 2020
0answers
0answers
7answers
Cant get past password i forgot it
There are a lot of Windows password revealers and crackers available, but I’ve found that Windows Password Recovery Tool is the most effective.:
it not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password
You can use the ISO to burn a boot CD. Follow these instructions:
1. Download ISO file from http://www.windowspasswordsrecovery.com Windows Password Recovery Tool
2. Burn to a CD using a CD burning tool such as Nero or Roxio or MagicISO
3. Insert CD into drive and reboot.
4. You may have to select an option in the BIOS to get the computer to boot from the CD.
Booting up and clearing a password takes a minute or two works like a charm.
11/12/2013 2:39:24 AM • Toshiba... • Answered on Nov 12, 2013
Will this model accept windows Vista?
Yes and No. In order to accept Windows Vista you would have to make sure you have sufficient RAM memory. These older Win XP based laptops usually only have 256KB or maybe 512KB of RAM memory. Vista needs 512K minimum, but you should relay max out the Toshiba to 1MB of RAM for Vista to run smoothly. You would also have to try to find all the proper device drivers for Vista, and Toshiba has not provided them for this model laptop. You may find that some device drivers just are not available for Vista, I could not find a Vista video driver for it.This will impact performance. The bottom line, is that you can surely put Vista on this laptop but it will probably not run as efficiently and as fast as Win XP.
11/10/2013 12:32:58 PM • Toshiba... • Answered on Nov 10, 2013
2answers
LCD screen is blank when lap top is on
My soultion may be costly. The reason I say that is taking apart a lap top is no walk in the park. In many cases you will need special tools plus if you pull one part to far you might rip the delicate cable that sends the signal to your lcd screen. When it comes to lap tops and hardware problems its better to leave it to the manufacture to fix. I know this is not a solution but I just want to give you a heads up of what kind of problems you will run into if you try to fix it yourself. I would call manufacture see if there is a recall or somekind of tech service. Then you will be rest assured that it will be repaired properly and there will not be more problems that you caused when you opened it up.
7/21/2013 12:49:52 PM • Toshiba... • Answered on Jul 21, 2013
Is this wireless ready or do i need a wireless devive
This model Toshiba does not have a wireless device installed.You need to install a PCMCIA wireless card or an USB wireless device.
6/30/2012 10:44:52 AM • Toshiba... • Answered on Jun 30, 2012
Bought used laptop and do not have administrator password
You can reset laptop password with Smartkey Windows Password Recovery, just do as the following steps,Step1: Download Smartkey Windows Password Recovery from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html. Step2: Install and launch it to any accessible computer. Step3: Use a blank and writable CD/DVD/USB to burn Windows password reset disk with the tool. Step4: Boot the locked computer from CD/DVD/USB. Step5: Start to reset laptop admin password with the burned disk. Step6: Reboot computer and login to the locked PC without password.
6/5/2012 4:05:23 AM • Toshiba... • Answered on Jun 05, 2012
0answers
Cant get passed password screen
I would recommend you go back to the seller and ask for it or your money back, because you will end up paying additional money. Go to www.ebay.com Type: bios password and list of sellers claiming to clear the password will be presented.
5/1/2012 8:55:03 AM • Toshiba... • Answered on May 01, 2012
A15-S129 slow performance with 1GB of memory
maybe the Toshiba is bugged up with viruses and infections.
4/23/2012 1:02:14 PM • Toshiba... • Answered on Apr 23, 2012
WHERE IS TAB KEY LOCATED
Hi:
Tab key is located at your left hand side above the Caps Lock key, the key has two horizontal arrows and is labeled Tab.
Good luck.
7/8/2011 10:14:42 PM • Toshiba... • Answered on Jul 08, 2011
My Toshiba Satellite A15-S129 is very slow How can
Saying a computer is slow really is not giving out enough info. The A15's came with 256MB of memory, and runs XP Home - which was barely adequate. So that'd be the first area I'd address: most computers run slow 'cause they ain't got enough memory, and memory is cheap, so it's a crime not to give it an upgrade. If you indeed have 256MB of installed memory, then you should add a 512MB module (it uses laptop DDR PC2100 or PC2700 memory) and that ought to do it.
7/5/2011 6:58:39 AM • Toshiba... • Answered on Jul 05, 2011
I am trying to connect
Hi, we have two ways to connect to broadband, via wired or wireless, at the device manager please do check if the LAN drivers are enabled, if enabled, via wired connection, simply put the RJ45 jack from LAN port of your router to LAN port of your notebook, if configuration is already set in your Router LAN, it will just automatically connect. If connecting via wireless press wifi button to activate wifi connection then windows will pop for your access credentials. simply put the password for your connection once the name of the site displayed.
6/21/2011 12:26:49 AM • Toshiba... • Answered on Jun 21, 2011
Sound driver is not working
You should be able to download the latest version for free from the Toshiba website, follow links for support and/or downloads entering details of you operating system and laptop model as you go.
2/5/2011 5:23:36 PM • Toshiba... • Answered on Feb 05, 2011
Toshiba Satellite A15-S129 Notebook Logo
109 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
tab key located
  • Computers & Internet
