20 Most Recent
Toshiba TE2100 Notebook Questions & Answers
WIRELESS SETUP CONNECTION FOR TOSHIBA TE2100
Go to the control panel. Open wireless connection wizard and configure it by giving the proxy setting of the router. There must be a DNS server to get you connected with the Domain.
First your os xp or vista
if u xp means go to network connection and see that tab, wireless network wizard and click next to open to next to next and click finish. It will appear in network connection windows. But u want to take airtel broad band wireless net key, and u open the tab if u finish ur network wizard tab. And it will open the icon it ask for key, u give it key to continue. It will ready to access the network, so this is the way
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
TE2100 ASKING ME PASSWORD AT
If your notebook asking you a password while you turn it on, probably someone is set your basic input output system(bios) configured to prompt for a password. There are two ways to clear your systems password 1. is you have to guess for the password 2. you have to clear the cmos or bios settings by removing your cmos battery from your motherboard for about 10 seconds. Then put it back again then on your computer. That's all have a nice day!
My computer may have a virus.....it won't go past
Hi. Try to drain the electorstatic energy of the motherboard. Remove the battery and unplugged the power adapter. Press and hold the power button for 30 secs then put everything back in. Turn on the computer and see if you will be getting the screen. If screen wont show up then this is most likely an LCD problem.
I can't clear the bios password on Toshiba Te
Toshiba BIOS passwords cannot be removed by taking out the BIOS battery. You need to construct a piece of hardware.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.
Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
I have a toshiba te2100
The problem seems to be over heating of the processor the fan of the heat sink is not working properly and the processor is getting hot and the laptop is shutting down to protect the processor,to confirm the fault remove the battery and charger for few min and then try to power on the laptop with the charger only if the issue resolved then the battery is defective.
Unable to format, partition,ins. os and boot my toshiba TE2100..
The CMOS needs to be set to first read the CD or DVD drive before it reads the Hard drive. Once your XP disk is in the drive it will boot from the CD drive and setup the computer, The CMOS is acessed by turning on the computer and immediatly pressing either the deleat key or the F! or F2 key try each one till you get to CMOS then look for boot section. Set CD drive to first your HD drive to second.
Ctrl x not work in xp
Dear Sir,
Since you tell me if Ctrl X does not work in XP... Have you checked if the X Key works in Notepad, MS Word...If it does then just shut down the notebook and restart it it will work....
My computer is Toshiba TE2100. When I update
No, all you have to do is continue the installation anyways; it is not harmful. In fact the warning only says it may be harmful. And I have never seen a case where continuing the installation has caused a computer to malfunction. So it is safe to continue the installation of your audio driver.
