20 Most Recent Toshiba Tecra 8200 Notebook Questions & Answers
I have a Toshiba Tecra 8200 laptop, i turned it
it will be fault of circuit board. you can use usb post diagnostic card for identify the error
9/23/2017 5:53:33 PM • Toshiba Tecra... • Answered on Sep 23, 2017
Upgrade toshiba tecra 8200 lan mini pci card
There are all kinds of lan cards available, go to www.ebay.com Type: lan card, or pci lan card.
4/10/2012 11:11:39 AM • Toshiba Tecra... • Answered on Apr 10, 2012
Disk error
Use operating system disk and run the command: chkdsk /r This will run for an hour or more but it will repair any boot and system files that are corrupt or missing.
3/10/2012 7:10:28 PM • Toshiba Tecra... • Answered on Mar 10, 2012
Wifi will not connect on dongle
has your pc installed the dongle correctly?
1/23/2012 9:18:25 PM • Toshiba Tecra... • Answered on Jan 23, 2012
My laptop screen does not
Burned out screen......another pc is in your future.
5/12/2011 10:47:36 PM • Toshiba Tecra... • Answered on May 12, 2011
I can only get a
I would check if there is any additional proprietary drivers are listed: Click you mouse on "System" then "Administration" and then "Additional Drivers". See if the is any video drivers listed. If at least one driver is there, you would like to install it.
Hope this will be the case
3/3/2011 10:12:10 PM • Toshiba Tecra... • Answered on Mar 03, 2011
My Tecra 8200 laptop's screen dims automatically
my toshiba tecra 8200 laptop have no display when power is on .
plz help me how 2 solve thios problem ?
2/2/2011 12:02:56 PM • Toshiba Tecra... • Answered on Feb 02, 2011
I Have Toshiba Tecra 8200
This item was designed fro use with Windows NT4 or Win2000 so XP may have driver errors.
If you have upgraded XP to SP3 try updates from Windows for a fix, otherwise re instalation of the original OS may be needed.
Have you run CHKDSK/F to check for hard drive errors? That is most likely to be the problem as if the drive is formatted to anything other than FAT32 you may be getting read errors.
Nice old machine. It will be a shame to have to ditch it.
1/10/2011 9:58:29 AM • Toshiba Tecra... • Answered on Jan 10, 2011
Does not find the extra
First--check how much memory the computer can take.
Make sure you don't exceed it.
Be advised that some brands of memory don't play well with others.
Be sure you are installing the correct type of memory.
10/15/2010 10:31:19 PM • Toshiba Tecra... • Answered on Oct 15, 2010
0answers
Just bought a used one.
PLug the AC adaptor with the laptop and start charging the battery.
wait for 5 mins and see if there is a indication of power on the laptop.
Usually on the left side at the top of your keyboard the power button is located you can press that to turn on the laptop.
Else there may be a problem with the laptop.
9/17/2010 12:23:44 PM • Toshiba Tecra... • Answered on Sep 17, 2010
How to clear CMOS password
25pin male connector"
This is a 25pin male connector which fits onto the printer port. You have to short-circuit the following pins:
1-5-10 / 2-11 / 3-17 / 4-12 / 6-16 / 7-13 / 8-14 / 9-15 / 18-25(optional) when u make it contect to your laptop and turn on laptop wait for 10 second .....then turn off laptop and remove printer port ..and turn on it again u never see the password.. Thanks
9/14/2010 7:28:43 PM • Toshiba Tecra... • Answered on Sep 14, 2010
Forget my password
1. Start up into safe mode (press F8 at startup) 2. log in as 'administrator' 3. go into control panels, users, and clear the password on the account that you have a problem. 4. restart.
9/1/2010 11:54:28 PM • Toshiba Tecra... • Answered on Sep 01, 2010
THE LAPTOP WORKS FINE BUT
Every laptop that is coming to the market has a button the bottom left just next to the "Crtl" button. This button says "Fn". On the other hand please find the buttons that are marked with dark Sun or a white sun. These buttons are for decreasing or increasing brightness. Just press down the "Fn" key (or button) and then press the key with the white sun on it. The brightness of the laptop screen will increase.
The keys with sun symbol on it are usually the arrow keys.
Good Luck!
8/4/2010 2:33:55 AM • Toshiba Tecra... • Answered on Aug 04, 2010
I have a Tecra 8200 bought as used fitted with
This laptop came with 128mb ram, you can safely install 2 sticks of 256mb for a maximum of 512mb with no bios update.
You need pc100 sodimms.
Amazon or ebay will be the best bet as this memory is expensive now from a retailer.
I found 256mb sticks for under $10 buy it now on ebay http://cgi.ebay.co.uk/256MB-SODIMM-PC100-SDRAM-256-MB-PC-100-LAPTOP-144-Pin-/190411543153?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item2c55699271
7/10/2010 10:08:57 PM • Toshiba Tecra... • Answered on Jul 10, 2010
Toshiba Tecra 8200 Notebook Logo
58 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Tecra Toshiba
  • Tecra Toshiba
Most Popular Question
toshiba tecra 8200 lcd screen use
  • Computers & Internet
