20 Most Recent
Toshiba Satellite P105-S921 Notebook Questions & Answers
Problem: Intermittent flashing horizontal lines
Could be hardware problem. You might need to try to connect to a different screen which you know is working. If it appear to be normal, it indicate that you need to replace the screen.
7/9/2013 6:02:36 PM •
Toshiba...
Answered
on Jul 09, 2013
My computer was working good
From your description I would guess that your battery ran out of juice. Insure that your battery is fully charged.
8/31/2011 6:59:19 PM •
Toshiba...
Answered
on Aug 31, 2011
I use TOSHIBA Satellite M200
Hi
There is software utility missing from your laptop
you can download it from TOSHIBA Satellite M200 website under ( keyboard utility )
Please tell us your results
Good Luck
5/13/2011 12:25:42 PM •
Toshiba...
Answered
on May 13, 2011
How can i connect my
If your laptop has a connector for TV, plug the cable then press Fn+F5.
3/18/2011 5:15:50 PM •
Toshiba...
Answered
on Mar 18, 2011
Hi we have a toshiba laptop model number
Hi Danial and Gin a,
Your right! It IS Overheating. Usually this happens by using a laptop on a bed or soft surface that doesn't allow the heat to escape from underneath the machine. If that is the case. Use a desk or table top to place it on. Here is what can happen. It can keep overheating and then after it cools down one day, it may be finished and not recover. So it is a serious matter to correct as fast as possible. Laptop repairs can be quite expensive.
Cleaning out the fan is an excellent idea. I would go down to your local Walmart, or computer store and buy a bottle of compressed air type cleaner for computers. I would blow the dust out of the fan. The third thing I would do is purchase a laptop cooling device that sits under the machine and helps cool it with its own fans. If you do this you should come out fine.
If you have been using the machine on a soft surface, putting it on a hard surface and blowing it out may be all that is necessary. Good luck,
Best Regards, Mark
12/26/2010 7:19:33 AM •
Toshiba...
Answered
on Dec 26, 2010
My computer keeps shutting down for no apparent
Possible causes of the problem:
- System overheating
- Virus infection
- Power supply malfunctioning
Solutions:
- Check your computer if the fan is properly working.
- Scan your computer for viruses
- Check your computer power supply by a qualified technician
- Reinstall your computer operating system
Try this also:
From the run box you can type shutdown -a and that should stop it from shutting down long enough for you to fix the problem.You need to look up how to remove msblast from your computer.
11/17/2009 1:49:33 PM •
Toshiba...
Answered
on Nov 17, 2009
Toshiba Satellite harmon/kardon overheating touchpad
Laptops to get hot, but not so they actually burn your fingers.
You say the fan is working and clean, ok , but when it kicks in does it stay on an excessive amount
of time especially under heavy cpu usage?
My first thought is you need the heatsink and arctic silver checked out on cpu, i could be wrong but it
sounds like your getting to the stage of overheating problems, and with prolonged use the laptop
will eventually at around 90C start cutting out.
6/14/2009 2:26:51 PM •
Toshiba...
Answered
on Jun 14, 2009
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM •
Toshiba...
Answered
on May 22, 2023
