20 Most Recent Toshiba (P000352520) Sound Card Questions & Answers
Sound
Try going to the manufacturers website and download the drivers for the sound card that you have. I'm not sure what model it is so I can't specifically tell you where to go. However, that will do it.
Please rate this answer! Thanks!
6/10/2011 2:22:04 PM • Toshiba... • Answered on Jun 10, 2011
I have sound problem in
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
11/9/2010 8:04:38 PM • Toshiba... • Answered on Nov 09, 2010
I need to download driver for my laptop ...after i
Which model & which brand u r using?
7/28/2010 7:55:51 AM • Toshiba... • Answered on Jul 28, 2010
I lost the user manual. Could you please instruct
1 open the cabinet door .
2 remove the dummy from the cabinet where you need to place the card.
3 place it in the PCI slot and fasten it up .
or try this video http://www.youtube.com/watch?v=wp4TDe814WU
7/5/2010 7:09:37 AM • Toshiba... • Answered on Jul 05, 2010
2answers
3answers
My computer has got a problem of sound drivers
Here is the link.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download
If you do not find your model, select the Toshiba site that serves the country where you bought the computer, and do the same search.
Hope it helps.
9/7/2009 3:46:41 PM • Toshiba... • Answered on Sep 07, 2009
Cannot locate Stereo Mixer
the sound properties should be in the "Control Panel" under sounds and audio devices then you need to select wich sound device or sound card you are using if you still can't see the device or the card there then you need to enable the card....do this by going to "My Computer" right hand click in the middle of the window (but not on a drive!!) go to "Properties" in the drop down menu it will bring up a system menu. if your a xp user go to "Hardware" tab and click on "device manager" if your a vista user go to "Device Manager" top left hand corner of the system window! once your in device manager either xp or vista (doesn't matter the device manager is the same) go to "sound,video and game controllers" click on the "+" next to it it should drop down with all the devices windows has reconised as sound,video and games etc controllers/hardware! now if the sound card your using has a yellow exclimation mark or "!" next to it then you have a hardware conflict and you need to find out what its conflicting with and either disable that or look at replacing your sound card you can also right click on the conflicted hardware and get the computer to try and work out the conflict....if it has a red cross or just says "disabled device" next to it then you need to enable it...do this by again right clicking and clicking enable and it should begin to work...now if its not there at all...then your computer has not recognised it as a sound controller or there is a problem with the drivers for that device so then try to re-install all the software for that sound card also try unplugging and plugging the card in and out.....you may get lucky and windows might detect it and it might auto install and it will work!! now being in device manager you can also look at the device itself!...do this by clicking on the sound card to highlight it and right click on it to a drop down menu then click on "properties" in this you can look through the drivers for the device..if you have a vista computer clicking on the device with a right click instead of clicking properties you can click on "scan for hardware changes" this will automatically scan for any changes in that hardware and may re-configure that change so it will still work on your computer!
hope this helps and good luck,ben
drop us a line if need anymore info!!
8/13/2009 4:48:56 PM • Toshiba... • Answered on Aug 13, 2009
2answers
No sound driver
5/24/2009 2:26:00 PM • Toshiba... • Answered on May 24, 2009
No sound driver for my TOSHIBA M45 S169
go to driverglaxy.com u can get from there
5/16/2009 9:24:44 PM • Toshiba... • Answered on May 16, 2009
Im having trouble with my
Please confirm make and model of operating system. If it is XP, then it is worth removing the hardware and restarting. You do this from Start,Control Panel , Add hardware.
Tell me if this helps.Then reboot and it should start by detecting the hardware and finding the droivers which you have.
1/9/2009 11:52:19 PM • Toshiba... • Answered on Jan 09, 2009
2answers
Audio
Go to run
type services.msc
look for Windows Audio under the Services Menu.
Right-click it and click 'Start'
hope this fixes it! get back to me :]
1/9/2009 11:42:57 PM • Toshiba... • Answered on Jan 09, 2009
How can i change my toshiba e-studio 263cs language from garman to english
Hi , Please follow the below steps -start menu -control panel -language -add a language -select language English -Open Button -Select the English region you want -Add Button
4/11/2024 5:54:15 AM • Toshiba... • Answered on Apr 11, 2024
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code: * Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error. *Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly. * Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error. * Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM • Toshiba... • Answered on Mar 26, 2024
Toshiba Satellite S55-A5275 will not boot up.
Joseph was using AI Chat GPT4 to answer questions and they are deleted because they are just guesses by an AI Bot and not specifically targeted to the OP question. Disconnect from the mains. Remove the battery. Press and hold the On button for 2 full minutes, timed. This will perform a very low level power reset for your power disconnect.
Toshiba laptop not starting up
Tom's Guide Forum https://forums.tomsguide.com > threads > toshiba-lapto... Aug 10, 2015 - First do a hard reset, remove the battery and AC adapter then press and hold the power button for 20 seconds. Turn it back on and see if gets ... 1 answer · Top answer: Hi, First do a hard reset, remove the battery and AC adapter then press and hold the power button for 20 seconds. Turn it back on and see if gets ... Toshiba Laptop not boot ' Tom's Guide Forum Dec 17, 2018 my toshiba laptop isn't start. how to fix it - Tom's Guide Forum Nov 16, 2018 Satellite will not run on battery power. - Tom's Guide Forum Dec 2, 2020 Toshiba satellite Laptop won't start after restart and goes to ... Jun 27, 2017 More results from forums.tomsguide.com Here is help on your error message. https://www.google.com/search?q=STOP+CODE%3A+ACPI+BOIS+ERROR BIOS Reset https://www.google.com/search?q=Toshiba+Satellite+S55-A5275+reset+bios General Toshiba Boot issues https://www.google.com/search?q=Toshiba+Satellite+S55-A5275+will+not+boot+up ..
2/28/2024 7:34:49 PM • Toshiba... • Answered on Feb 28, 2024
Codes for toshiba remote CT 90232
It isn't the codes for the remote that matter, it is the television that you want to operate. HOWEVER, this particular remote is custom made for one Toshiba device only!
Toshiba CT-90232 Factory Original Remote Control for TV's
Amazon https://www.amazon.com > Toshiba-CT-90232-Factor... Toshiba CT-90232 Factory Original Remote Control for TV's ; Compatible Devices. Television ; Connectivity Technology. Infrared ; Controller Type. Button Control. Rating: 4.9 · ‎7 reviews · ‎US$14.99
11/11/2023 6:46:06 AM • Toshiba... • Answered on Nov 11, 2023
Ct 90343 manuel Toshiba remote control
The Toshiba site I am providing a link to offers yet another link near the bottom of the page for downloading the manual to this remote. It also appears that the remote is purchasable and that even alternatives to it are provided. Here is the link: https://www.replacementremotes.com/toshiba/buy-ct-90343-ct90343-75017769-tv-tv-remote-control
11/4/2023 9:51:44 AM • Toshiba... • Answered on Nov 04, 2023
How to fix tablet toshiba wt8-a
Ensure the cd rom is empty and the bios is set to boot from drive C first, then drive D. If all in order and it still doesn't boot, try a system disc in the cd rom.
10/11/2023 4:56:30 PM • Toshiba... • Answered on Oct 11, 2023
Lenovo Yogo 6 is asking for a password to the Toshiba memory for the harddisk security. How do I find the password without taking the laptop apart?
Hard disk security passwords are typically impossible to find or bypass without the right password.If the Toshiba memory is asking you for a password, kindly check If the laptop arrived with any manuals, they may contain the password or instructions on how to reset or retrieve it. the other option If a user's password is forgotten, several hard drive manufacturers offer master passwords that can be used to open a disk.
8/11/2023 11:04:52 PM • Toshiba... • Answered on Aug 11, 2023
Toshiba DP5022C SDM phone message setting and voice retrieval - urgent need.
Try the Reset on page 100 of the manual for 5000 series Initialize Telephone Settings This function resets all Programming Mode option settings to their default setting. 1. Press 3+6+9+Hold (simultaneously). 2. Press Mode soft key. 3. Press Msg button. 4. Press Hold. 5. Press Vol 'Up' button. 6. Press Msg 7. Press Hold 8. Go off-hook, then on-hook to exit the program mode https://www.compuvoip.com/documents/ug-dp5000.pdf ..
6/13/2023 6:56:40 PM • Toshiba... • Answered on Jun 13, 2023
What is The purpose of USB input on a Toshiba DR430?
5/1/2023 7:50:06 PM • Toshiba... • Answered on May 01, 2023
Computers & Internet Logo
18 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Computers & Internet
Most Popular Question
need sound drivers toshiba satellite 60
  • Computers & Internet
