20 Most Recent Toshiba 25 PACK DIGITAL STYLUS PEN FOR M200 M4 R10 TABLET PC (PA3316U2PK25) Questions & Answers
Toshiba tecra M2 LCD Screen
A pinkish tint is indication that the backlight tube inside the screen is not fully lit. But then it goes black - meaning the tube shut down? That part don't make much sense - it's certainly possible, though.
Replacing tubes is pretty surgical so I wouldn't recommend it. Replacing the screen should be pretty darn easy. A good, used screen should be pretty cheap on eBay, so that's where I'd start.
3/19/2010 5:10:08 AM • Toshiba 25 PACK... • Answered on Mar 19, 2010
I have toshiba tecra m2
hi friend
Press F8 Just after you press the power button.
a window will open select safe-mode use the arrow keys to select and hit enter .then safely restore the computer using system restore.or uninstall the graphics Driver from control panel.the drivers that you were going to install was digitally signed?
this thing usually happens when you install an unsigned driver . click her to know hot to use system restore
please rate me
3/5/2010 12:05:45 PM • Toshiba 25 PACK... • Answered on Mar 05, 2010
I need to change the tip of the stylus
I own a Toshiba Tablet PC that uses a wacom stylus.
With the stylus replacement tips there is an extraction tool: It looks like a wide ring split lengthwise.
You take the tool between thumb and index ( as you do a tweezer) and extract the worn out tip.
Toshiba warns against letting the tip wear out too much: this renders extraction difficult.
Once you have extracted the worn out tip, insert a new one with the thinner side towards the outside.
Press gently but firmly to make sure it is holding.
Hope it helps.
8/22/2009 2:13:34 AM • Toshiba 25 PACK... • Answered on Aug 22, 2009
How can i factory reset my toshiba tablet modle wt10-a
There should be a little hole somewhere on the tablet. Stick a pin in it then it should factory reset it. Or if you can, create a new user then go to settings and factory reset it from there.
10/7/2019 2:49:20 AM • Toshiba Tablets... • Answered on Oct 07, 2019
How do I connect a Samsung tablet to a Toshiba PC?
have tried connecting with usb cable
5/13/2019 7:04:39 PM • Toshiba Tablets... • Answered on May 13, 2019
How do I pair up my tablet to my Toshiba tv
Miracast is the only way with an android device unless your Toshiba TV has file sharing/media sharing apps on it.
1/10/2019 5:57:23 AM • Toshiba Tablets... • Answered on Jan 10, 2019
On my toshiba tablet,I forgot my pass word.how do I reset it?
Not sure about specifics on toshiba tablets, but wanted to suggest that on other tablets you can hold the up volume(sometimes others its volume down) and power button at sane time for about 10+seconds and a menu will pop up for a rebooting, safe mode, and factory restart(which erases and reboots from scratch) worth a shot.. Yet, be careful what you select if it works.. Don't want you to erase stuff if you don't want to.... And btw most tablets have a little pin size hole either under the camera lense or on side that something like a paper clip can push a reset button... But don't think that helps with password.. Just if it freezes up and won't shut down... Good luck.. Sorry if this doesn't help...
12/24/2017 9:07:03 AM • Toshiba Tablets... • Answered on Dec 24, 2017
0answers
Tablets & eReaders Logo
4 questions posted
Top Toshiba Tablets & eReaders Experts
k24674
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Tablets & eReaders
Most Popular Question
need change tip stylus
  • Tablets & eReaders
