20 Most Recent
Toshiba DKT2010H Phone Questions & Answers
Banked call?
Message waiting can come from several sources. Usually they are stacked at the phone and you can keep pressing message until they are all displayed. Have the person down the hall pick up the phone when you ring it, or look for the message cancel code and get that message off your set. If it clears, that was the only one and you have no voice mail messages.
Carl
PROGRAMMING SPEED DIALS ON TOSHIBA DKT2010H
To program speed dial press speed dial then redial then the bin number (10-49) and dial number then press redial. If you mean to program the buttons on the right hand of the phone this is done is syatm program 39 and the manual can be found here'
http://guides.idacomusa.com/
What is the code to turn on the ringer of our Toshiba DKT 2010-H
It can be done, but it is not an easy task that I could walk you through. Essentially, what you're talking of doing is using a Night Transfer that you could toggle on and off. Once setup, it would be very simple for you to manage. However, this is an advanced procedure and I would recommend you having an installer do it for you.
You can browse Idacom's guides and manuals
here and possibly find what you're looking for.
Toshiba DKT-2010 H
Is the flashing light the message button or a lot of the buttons ?
If it is the message button then press Intercom/DN, # 409 and hang up. That is the code to cancel a message waiting light. If random buttons are flashing you probable do not have the phone plugged into a system port. Try plugging the new phone into aother jack with the same type phone to see if the phone is good or bring a known working phone and plug it into the jack you are using for the new phone and see if it operates the same way, that will let you know if the phone is bad or the jack is not wired for your phone system. Good Luck
