20 Most Recent ViewSonic VP201b 20.1" LCD Monitor Questions & Answers
Monitor distorting in screen halves after warmup
It probably isn't worth repairing as the cost will exceed what you would spend on replacing it.
9/11/2009 8:20:24 PM • ViewSonic VP201b... • Answered on Sep 11, 2009
ViewSonic VA2431WM monitor. How do you open the case please?
Question edited for clarity Videos for ViewSonic monitors, various models. There are notches along the edge and you use a Spudger Tool. https://www.google.com/search?q=ViewSonic+VA2431WM+open+case ..
12/23/2023 3:27:52 AM • ViewSonic... • Answered on Dec 23, 2023
2answers
Viewsonic vx922 capacitor compaiable va1930wm montor
As long as they are the same value
3/2/2022 5:24:34 PM • ViewSonic... • Answered on Mar 02, 2022
2answers
Vx922 capacitors will they work on a viewsonic va1930wm
https://www.youtube.com/watch?v=X6Tn6a_Xy7Y
3/2/2022 5:23:57 PM • ViewSonic... • Answered on Mar 02, 2022
My monitor is all purple and white how do I fix that on a viewsonic
https://www.youtube.com/watch?v=-EfwZnWYrvI
3/2/2022 5:23:47 PM • ViewSonic... • Answered on Mar 02, 2022
Viewsonic VX2835wm monitor that powers up with a good screen for a couple of seconds and then goes blank. I replaced the power board and it still does the same thing. Could it be the on/off switch?
FIRST WE DO NORMAL AND LATER TRUE CAUSE. gee that is normal on all monitors and by Energy Star laws too. the monitor if the PC is dead or in speed mode, shuts of in 15 to 90 seconds, all do, every one. the monitor has self sleep, all do. everyone ever made did. even back to CRT days. and the OSD button goes dead after. that. too. fooling the untrained. here is the first tests, NO PC connected at all power on see power light glow correct color then see Viewsonic splash screen push the menu button now. quickly, if button dead hold it for 10 to 15 second to reverse the button lock now, see OSD works. if you test the monitor on a good PC not in sleep mode the but working PC, your monitor is ok. this monitor is very very old, 2004? it has CCFL back lamps not LED< and all fully used CCFL lamps are now no good, used 8yrs a day at 5years are no good. that is why we use LED back lamps now. this is what they do: all do , used fully. 1: goEs dead forever, (vast did) 2: INTERMITTANT . (BINGO YOU ) OR INVERTER DEAD. 3: DIM BULBS (like me. lol) 4 TURN YELLOW FOR WHITE screens. 5: STROBEs. (FLASHes) AND A VERY EXPENSIVE SURE, THAT. AND LABOR.
3/2/2022 5:23:35 PM • ViewSonic... • Answered on Mar 02, 2022
2answers
Viewsonic VX2880ML 4K monitor, front vontrols won't work, help.
power on and power on led glows normal , not yellow or flash. then this happens splash. attached, 2014 made. then that tells you screen is NOT DEAD is it? now? here? (PC is dead or missing)
  • NO connections on 1 or more inputs.
  • NO sync
  • no signal
  • OUT OF RANGE
and goes black screen NEXT,. if all that fails power supply is bad. if all that works the menu button works for 15 seconds turned on with no PC, and also works on all PCs if connected to one that are all good and not sleeping. test the monitor on 2 PCs if confused. splash-undefined-undefined-0.jpg
3/2/2022 4:55:16 PM • ViewSonic... • Answered on Mar 02, 2022
2answers
My new Viewsonic VX monitor shows "no signal" when connected to computer.
that means just what it tells you the PC is dead, PC video dead or video cable unplugged , dog chewed it , pins bent or plugged in wrong on 1 or both ends. or monitor not selected to the correct input port (OSD) PC power lamp glowing not amber or blinkikng PC fans spin , PSU fan and CPU both if PC has GPU card in PCI-express slot it must be use those ports only for video. PC not beeping PC not texting errors post. PC not blinking codes on LED or caps lock or POST ERRORS ! NO PC told PC dead. PC not stuck in sleep mode , hold PC power button for 10 full seconds to end it, (cold boot that is) test monitor on end good PC? yet?
3/2/2022 4:54:28 PM • ViewSonic... • Answered on Mar 02, 2022
Screen won't come on, on my Viewsonic VSR220
WHY DOES THIS SEARCH SHOW.The Viewsonic VSR220 no such thing.?Turn the monitor around, 180 and see the TAG sticker with real model toldno PC told , what PC is this?this ? VSD (D key is next to R) so huge typo"?https://www.viewsonic.com/eu/products/lcd/VSD220yes that is a PC (android)but can do monitor like duty. too.it needs service.if screen is dead, it has power problemsas the screen must at least show a viewsonic splash as power is turned on.try it on a 2nd room AC power jack yet:?if in warranty take it back to the storeor call viewsonic for help.the android PC can use an HDMI cable to a PC and works as a monitor.too.the manual states"4.5 Connecting to HDMI-compliant Devices via MicroHDMI InputHDMI (High-Definition Multimedia Interface) is a compact audio/videointerface for transferring uncompressed digital audio/video data. You canobtain the best user experience for video playback and gaming via HDMI.VSD220 is equiped with a micro HDMI input for connection to an externalHDMI-compliant device. You can connect your PC, notebook, Blu-ray playeror any other HDMI-compliant device to VSD220 for high-definition videodisplay."
2/16/2022 7:47:31 PM • ViewSonic... • Answered on Feb 16, 2022
2answers
ViewSonic VA2261H monitor leaning forward, how to adjust?
hi find link for view sonic user Manual https://cdn.cnetcontent.com/61/f2/61f22225-fb19-4df8-b503-b4cacc6d84ea.pdf
12/31/2021 6:00:29 PM • ViewSonic... • Answered on Dec 31, 2021
How to remove back panel of viewsonic va2046
Hello Edelberto, this monitor does not disarm by the back to disarm the monitor, you have to remove, with great care, the front frame and there you will see the obstacles you have to remove the panel assembly and the platelets I hope you can disarm it, comment the results Greetings Franco Dosil Hola Edelberto,este monitor no de desarma por la parte posterior para desarmar el monitor, tienes que retirar, con mucho cuidado, el marco frontal y ahi veras las trabas que tiene para sacar el conjunto del panel y las plaquetas Espero que puedas desarmarlo, comenta los resultados Saludos Franco Dosil http://www.viewsonicglobal.com/public/products_download/36/29622.pdf http://www.viewsonicglobal.com/public/products_download/36/29639.pdf
5/13/2019 1:16:45 AM • ViewSonic... • Answered on May 13, 2019
VGA Monitor starts flickering brightly after 20-30 minutes of use
The problem is seems to be in power supply section. it may be need to repair by electronic technician, after using any monitor 5 to10 years there may be power section or lcd panel may be damage.
1/30/2019 6:15:31 AM • ViewSonic... • Answered on Jan 30, 2019
I have a Viewsonic VE710b monitor. When I connect it to my computer and turn both on, the monitor shows a "No Signal" message. I've checked the connections and all are good. Is my monitor damaged?
First, I'm not a Viewsonic representative. * Check your warranty. call for support. *** Following for information only.*** * No signal means no usable signal for a specific input on the TV or monitor. * If it's just a monitor and not a multi-function TV that also has a Computer to video input then you need to check the device that's hooked up to the monitor as single function monitor's usually only have one input. * If this is a TV then you need to go to the TV menu and check the "Input Source" to make sure it's on the input plug your using. (I'm using HDMi-2 on my laptop to TV) * If it's not on the correct input then there will be a different signal (DVD, VCR, etc.) or none at all (No Signal) if those units are turned off. * Unplug all devices (to reset) and count to 10. Power up and perform set up to your existing configuration. * Note; as of Jan 2018 most cable TV are not broadcasting in analog (chan 3) and must use a digital tuner to get signal. Some cable Co. provide converters (for a fee?) * Check with your service provider for more information. Aloha, ukeboy57 PS, If you do have a damaged input (or feed) then check your video device for alternative outputs; IE: RCA Vid-Right-Left audio, HDMI, Split video (Y-G-B), VGA, S-plug, etc.
12/30/2018 6:37:33 PM • ViewSonic... • Answered on Dec 30, 2018
My Viewsonic T-46 is stuck in scanning and repairing C drive on start. Can I stop or work around this?
no PC stated. no OS stated, so... weak answers... next.actually only old windows did that! once it needs to do that, that means the HDD shows errors. they are not ever supposed to show errorsand in fact self repair them selves (2001 to now HDD)what I do is shut the PC off.them test the hDD as remote disk and run smart testsor boot the same PC with say linux demo disk (or usb stick)and RUN SMART test.if the fail the HDD is no good. hopeless cases.the next actions is backup data.the PC you have running silly old chkdskwill actually damage more data doing that,that is why w10 does not do that, it just tells you smart fails on HDD0 or the like.Just 2 steps of you have the linux media pre made.as all techs do.no PC stated and viewsonic is not a PC.boot to linux, click try me, then run disktestif it fails smart tests the hdd is bad.http://pcdied.com/linux.html
12/22/2018 8:24:18 PM • ViewSonic... • Answered on Dec 22, 2018
Va1928 opening case - ViewSonic VA1928wm Monitor
so you want to open the va1928 case.did you take off the stand and full remove the stand mount first.and see screws hidden there, did you remove all screws on the back first? the mount is steel and has 4 screws , off those first.the book is free to read, users guidepage 10, says wall mountthis 1 page shows,1: remove the snap off lastic panel first. that normally hide cables on rear, or just hides the steel mount.and the magic 4 screws on it. then pry it.steps 1 to 4, page 10https://www.manualslib.com/manual/266493/Viewsonic-Va1926w.html?page=10#manualthen remove all other screws you see and it comes apart.this is close, nice clear english too. refreshing.https://www.youtube.com/watch?v=UJuMdIUQ_k8 the pr ytools are; in order of best to worst are.1: using std, cell phone pry tools.2: using a Guitar pick,3: wreck your CC , us an old useless credit card.4: now use screwdriver an mangle the edges for "art"5: claw hammer it? or a finely sharpened crow bar?
12/22/2018 8:20:21 PM • ViewSonic... • Answered on Dec 22, 2018
My Viewsonic VW2439WM dual display monitor now has a green tint.
VW? what is this VW? prefix? VX or VG is common,Im guessing VXthe manual has no word "dual" in it,so that is perplexing.are you attempting dual displays on 1 PC, (unstated PC)yes, /nothe VX has 3 inputs ports, dvi, vga and HDMIi guess the VGA port fails.why not use VGA to DVI adapter, even as a test. dirt cheap too.why not test any monitor on 2 PC'S Not just 1.then you learn if the monitor is good or bad, in one simple step.?why ask this? you told me HDMI works so why not use HDMI.or does the VGA port must work for other computers, we dont know how any one uses monitors, the possibles are endless.even as service monitor, ok?if the VGA fails on 2 PCs, (it spec resolution) the port is bad.RGB, did you reset the monitor first, do the OSD reset stated in the manual. sure worth a shot that....called RECALL in the manual please read the manual. page 15.page 12Color Adjust provides several color adjustment modes, including preset colortemperatures and a User Color mode which allows independent adjustment ofred (R), green (G), and blue (B). The factory setting for this product is 6500K(6500 Kelvin). make sure not fiddled wrong?
12/20/2018 1:11:46 PM • ViewSonic... • Answered on Dec 20, 2018
Can a viewsonic vsd220 smart monitor get firmware updates
no , leave it alone if a monitor runs perfectly do not mess with that. but yes, only Viewsonic.com can help, only them. they made it we make nothing at all here,.
12/18/2018 10:48:50 PM • ViewSonic... • Answered on Dec 18, 2018
I just installed a Dell
Have you tried 1234 or 0000. These are common codes for bluetooth devices that don't give a random code.
If that doesn't work, try connecting the tablet to the laptop instead of the other way around.
1/21/2018 7:25:10 PM • ViewSonic... • Answered on Jan 21, 2018
ViewSonic VP201b 20.1" LCD Monitor Logo
Popular Tags
2 questions posted
Top ViewSonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ViewSonic Computers & Internet
Most Popular Question
monitor distorting in screen halves
  • Computers & Internet
