20 Most Recent
ViewSonic VP2030b 20.1" LCD Monitor Questions & Answers
For a long time the
Probably not a setting
If you are on windows : Can you change the power setting in the interim , to stop it going into hibernation - sleep mode
settings > control panel > power options>high performance should be clicked and then click change plan, PUT THE COMPUTER TOP SLEEP > NEVER
Does not solve the intial issues, but tis impossible to diagnose in this forum
Hope it helps
4/21/2017 7:03:44 AM •
ViewSonic...
Answered
on Apr 21, 2017
I just had had it
Can you be more specific about "went wrong"?
Are you looking for repair help or are you just venting?
These are wonderful but complicated monitors.
I have sucessfully repaired many.
Monitor Mike
1/16/2011 5:09:11 PM •
ViewSonic...
Answered
on Jan 16, 2011
Problem: no image, black everything,
Unplug the cabels and plug it back in,Have you tried this already?
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
1/10/2011 2:05:42 PM •
ViewSonic...
Answered
on Jan 10, 2011
I have two Viewsonic VP2030B monitors that both
wa7tuv, If the plastic front "bezel" is very thin and the monitor control and setting buttons are located on the verticle sides of unit, it just may be that the "bezel" will need to be parted from the rear cover, with the glass lcd panel left in the rear panel. Then you will need to remove screws so you can get lcd panel out of the rear cover. You might just get lucky and find a video of some owner/technician doing a tear-down if you search YOUTUBE using "lcd monitor disassembly" or "lcd monitor repair" as search terms. Be very careful and protect the glass lcd screen at all times. It is the most expensive part of the unit. You CRACK the glass, It's you bought it, you own it, Toyota!!!! You could also check with Viewsonic to see if they have a cash+old unit exchange program for out of warranty,but prematurely failed units that will be swapped for same model "refurbished units????? 12fixlouie
9/17/2010 3:03:56 AM •
ViewSonic...
Answered
on Sep 17, 2010
Adjust zoom of monitor
mcdevito75 here, You can try going into Menu on the monitor or you can press the auto on your monitor to retrn to factory settings.
7/14/2010 1:23:52 AM •
ViewSonic...
Answered
on Jul 14, 2010
Usb port dead
You may have blown fuse for the 5VDC line for the USB port, you need to check PIn 1 of the USB to see if you do have 5VDC, if you do, it can be damaged USB interface chip, or it can be as simple as bad USB cable. Did you verify that the USB port on your PC is OK?
4/5/2010 3:06:22 PM •
ViewSonic...
Answered
on Apr 05, 2010
Viewsonic vx910:green power light
Te blinking power light is a good indication of the blown power supply. If you want to try and fix it you can check out some pictures of what the bad capacitors look like at:
www.ccl-la.com/badcaps.htmYou can look at some of the repair guides e have posted and get a good idea how to dis-assembly your monitor to look for the bad caps. Just replace any that look like the pictues show and yo should be back up and running. If you would prefer to not do it yourself we do have a repair service for this issue. Email me and we can setup up a service ticket.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
3/9/2010 5:12:01 PM •
ViewSonic...
Answered
on Mar 09, 2010
When turned on, monitor power light comes on for a
This is a common problem on these monitors. There are three or four
capacitors in the power supply, three on the inverter board and anywhere
from 2 to 6 on the main board that go bad.
The number on the main board depends on how long the monitor has been
having problems before it was serviced. The longer the wait, the more
capacitors will have gone bad.
The power and inverter boards are easy to repair, the main board is not.
As mentioned, it is a multi layer board so removing the old capacitors
and the old solder can be troublesome. I would suggest you have someone
experienced at soldering repair the main board.
Btw, our shop would charge $60 labour plus $2 for each capacitor.
3/9/2010 5:09:58 PM •
ViewSonic...
Answered
on Mar 09, 2010
