20 Most Recent
Zebra P120i Thermal Card Printer Questions & Answers
I'm printing a double sided
It may be that the ribbon is mispositioned. There are quite a few points in the trouble shooting section of the owners manual. These start on page 53. Here is the link to the page at the zebra company site that you can download the manual from.
http://www.zebra.com/id/zebra/na/en/index/products/printers/card/p120i.4.tabs.html
Hope this helps,
Best Regards,
Mark
Mechanical error
Mechanical error can be a lot of things, you have to take the printer to a tech so he can open and see if orange ribbon its lose and need to be replaced.
Insert black crd message zebra p120i
Dont worry, this is not error! The printer is asking to continue with calibration procedure:
After a few seconds, the printer prompt for the black card when it displays "INSERT BLACK CARD" so, Feed the black card through the front of the printer (where the card exits through) with the black side up, until the printer takes the card in automatically. You will get one of two results: a. RIB SENSOR PASS. Indicates the ribbon sensor was calibrated successfully.
My zebra p120i wont print, it just says error in print command.
Printer and Drivers(W XP), Printers(W Vista or higher version) Go to the driver by right clicking and printer preferences, then go to the tools settings, you will see the possibility to print a Test Card...Print it. If nothing happens and you are sure you have the supplies, Connection and power, it means you should check on the cable.
