20 Most Recent
Zyxel Prestige P-330W Wireless Router (P330W) Questions & Answers
Zyxel will not connect to my laptop wirelessly
Step 1 - If your laptop contains an ethernet port for a wired connection -- connect it to the router using a wire. Try to use the internet -- if it works we are assured the router to the internet is correct.
Question 1 - Please respond to this with the make and model of your laptop and if you have one the make and model of wireless adapter for use with the computer.
Question 2 - Was this router originally purchased new or used?
Question 3 - Has this router work wirirelessly with any other computer you know about?
Question 4 - Have you configured this router since you got it?
Question 5 - Have you had someone else configure this router since you got it?
Router disconnects several times weekly.
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Configure Home Network- 8 digit PIN?
There are two ways of finding it:1st - Check the sticker or box of router. You can find it near the serial number or mac address written. It is mentioned as PIN Number. 2nd - Login in the router page with default password and you can find it on settings page.
Turbo Kits For BMW
Can access the wireless
Great! If you have a problem, or cannot access the router later, post a new question here.Be sure to be specific about what the problem is, and what you have tried to resolve the issue.
I don't know how to
hello. try this. open your web browser and type in adress link = 192.168.1.1
this will take you to your rooter's configuration page. search for wireless settings tab or somethign like that and from there you can enable password protection.
ps: when you type 192.168.1.1 it will propably ask for a password. I hope you have the password for that. If you dont remember it try username: admin / pass: admin which are usually the default.
hope that helped and please dont forget to rate, helps a lot.
cheers
I have a ZyXel P-330W
Plug directly into the P-330w and open up a browser. In the address bar type in 192.168.1.1 (or 192.168.10.1) and hit enter. The login will be username: admin password: 1234 If those don't work you'll need to reset the router to actually get back into the settings. Once you are logged in click on Wireless on the left side of the screen and then Security.
If your encryption is set to WEP, click on the "Set WEP" button to the right. The Key1 box is your wireless password. If the encryption is set to WPA then look down near the bottom of the page where it says WPA Pre-Shared Key. The box next to that is where you can type in the password. Retype a password that is 8 or more characters and click Save at the bottom.
Then you should be able to use that password on all your computers when connecting wirelessly.
Hi, how can i reset
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
I cannot access the internet
I suspect the issue is not the firmware- check the security settings you have for your wireless network. If you are using Windows Vista/7, it would be through Network > Network and Sharing Center > Manage Wireless Connections > right click on the appropriate connection, go to properties and look for security. Check with a wired pc what the settings are in your Zyxel- match, and you should be able to connect wirelessly I’m happy to help further over the phone at
https://www.6ya.com/expert/susan_42b401e0b1603d8a
