20 Most Recent
Archos Gmini XS 100 MP3 Player Questions & Answers
I bought a archos 3 mp3 player back in august and
Have it observed within 24 - 48 hours if they are functioning well and if the funny colored screen is still there within 2 days, contact the company that you have purchased the device and asked them about the warranty policy and have them replaced.
Error de lectura
Verifica los cables de conexi?n SATA. Si est?n bien, el problema es grave, lo m?s seguro que ya perdicta tu disco duro
Xs100 battery
its a rechargable battery! much easier to buy another mp3 player!
I have the Archos Gmini XS 100 4MB and am
probably means your pc doesn't like it for some reason. i have XP too,and that happens to me sometimes. try plugging it in then taking it out again then putting it back in. if not, look at the properties of it.
I take my MP3 to school, and one day I got it out
sir u say there is a black line in the middle of the screen............
its means your mp3 is over charged and its integrated circuit i.e IC
damaged...
u can't repair it your self........
sir u hav to go and repair it any ...mp3 reapirer shop ok
best of luck...
if any prob type in comment
I cant put songs on to my MP3
Go to Control panel>Performance and maintenance> System> Hardware> Device manager> Universal Serial Bus Controller, click on the + sign to see the list of installed devices. If your player is connected, it should be listed there with a yellow flag (the yellow flag indicates that although the connection is there, it is not working properly). Right click on it>Properties>Troubleshoot. See if the troubleshooter can help. If not, click on Action on the top bar and then Uninstall. Leave your shuffle on and connected and reboot. XP should now recognize and install it.
Another possible solution.
Click on Start, click on Run and type the following in the opening textbox:
cmd
and press the Enter key
A window will open (black and white) and will display the following:
C:\Documents and Settings\Your Name\
Type the following at the end of the above line after the \
Net start stisvc
And press the Enter key
You will get a message that service is already started (if so this does not solve the problem) or that it is starting (if so this may solve the problem). Then try connecting your camera after you close this window. To close this window, type EXIT at the end of the displayed line and press the Enter key.
Yet another possible solution:
Open Tweak UI if you have it. Get it if you don't. In Tweak UI, open the My Computer tab/line and click on Drives. A list of all possible drive names will appear with the ones you want to show in My Computer checked. If your removable storage/generic volume/camera drive as shown in Device Manager (mine was F:) is not
checked, check it. The drive will appear in My Computer.
If your drive is already checked, it's something else.
Tweak UI can be downloaded from the following site:
Windows XP PowerToys /
free download
http://tinyurl.com/36n
Good luck! let us know what (if) worked
Hard drive
hi
what probebly had happend is that you earased your system files along with all other (stupid manufacturer)
you need to install your firmware again:
http://www.archos.com/support/download/firmware.html?country=global&lang=en
next thing to do is dowloding and insalling all links from this page: http://www.archos.com/support/download/index.html?country=global&lang=en
good luck
