20 Most Recent FIC K7MNF-64 nVidia nForce 2 Socket A mATX MB w/Snd, VID LAN Motherboard Questions & Answers
0answers
Need the photo of where
Please refer first to your motherboard manual to find where your power switch and reset pins are located. >>
emachines/manuals/K7MNF-64_manual.zip
PDF manuals require the Adobe Acrobat Reader for viewing and printing. http://get.adobe.com/reader/
9/13/2011 4:17:30 PM • FIC K7MNF-64... • Answered on Sep 13, 2011
I am just trying to purchase a new battery .. for
3.0vdc-3.5 vdc battery number CR2032
11/16/2009 7:47:05 PM • FIC K7MNF-64... • Answered on Nov 16, 2009
0answers
2answers
What is max memory for fic k7mnf-64
Supports up to 2 GB RAM 266/333/400 (aka: PC2100/PC2700/PC3200)
9/11/2009 10:01:11 PM • FIC K7MNF-64... • Answered on Sep 11, 2009
Emachine w3052 will not connect through ethernet
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. via
qpoii6
9/8/2009 12:07:29 PM • FIC K7MNF-64... • Answered on Sep 08, 2009
Constant tone when operating
A constant beep usually indicates that there could be a loose card in the case, check that memory is seated properly, also check your graphics card and any PCI cards that are inside the case are seated properly.
Good luck
6/17/2009 12:45:54 PM • FIC K7MNF-64... • Answered on Jun 17, 2009
2answers
Cannot find optical drives
The IDE cable comes with 3 IDE plugs. The longer end goes into the motherboard. The two close together goes into the two dvd drives. If you take out the DVD drives, make sure that both are not set on master. At the rear of the drive where the power and IDE connects, there is one jumper that is in line with the letters C, S or M for Cable Select, Slave and Master, respectively. One of the drives should be set to master and the other as slave. Turn on the computer and you should be able to view both drives now. Let me know if this solves your problem. Lolita
4/11/2009 7:59:04 PM • FIC K7MNF-64... • Answered on Apr 11, 2009
Need Network adapter
Install the nForce 2 motherboard drivers. The onboard network controller drivers are part of the package.
4/11/2009 7:58:14 PM • FIC K7MNF-64... • Answered on Apr 11, 2009
2answers
How can i solve this problem??
i need to know were the power sw and the p led +, and the p led -, and the hdd led , and the reset sw go on the mother board go
3/23/2009 11:16:43 PM • FIC K7MNF-64... • Answered on Mar 23, 2009
Fic k7mnf-64 motherboard socket 462
Power is not going to the board. Check the power supply cables going to the board; most use a big 20 pin connector & a 2nd 4 pin connector. Make sure both are plugged into the proper spots then retry boot. Should see a green light on motherboard if power is properly set up. Hope this helps.
2/8/2009 11:27:45 PM • FIC K7MNF-64... • Answered on Feb 08, 2009
Can u fix this?
That means that ur CPU is shot. That means ur CPU is no good.
1/16/2009 12:28:08 PM • FIC K7MNF-64... • Answered on Jan 16, 2009
User manual lg ce 0168
http://www.freeproductmanual.com/lg-ce0168-user-guide/pdf-manual-lg-ce0168-user-guide/
5/11/2014 5:00:39 AM • FIC Computers &... • Answered on May 11, 2014
0answers
Computers & Internet Logo
Popular Tags
15 questions posted
Top FIC Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • FIC Computers & Internet
Most Popular Question
max memory fic k7mnf 64
  • Computers & Internet
