20 Most Recent Fuji FinePix S9000 Zoom Digital Camera Questions & Answers
Finepix S9100 humming type motor noise
there is a setting on the left side of the camera- you have it set to constantly focus. I had the same problem
1/27/2018 4:59:15 PM • Fuji FinePix... • Answered on Jan 27, 2018
S9000 camera shows batteries to be discharged, but battery tester shows all four to Duracell copper tops to be fully charged. Any suggestions?
There could be a malfunction of the camera.When something is blocked in the camera, the electronic will shut down, to prevent extra damage. Sometimes the lens is stuck and won't come out. This could have lots of causes, but it could overheat the motor or bring extra damage to the gears. In those cases the batteries can be drained very quick.Sure you checked all contacts of the batteries? They should be clean and shiny. Never use a sharp tool to remove oxide or grease from electronic contacts Only use a dry cloth or special contact oil.
11/14/2013 4:35:20 PM • Fuji FinePix... • Answered on Nov 14, 2013
Does not work the connection between the camera
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
8/2/2013 2:16:26 PM • Fuji FinePix... • Answered on Aug 02, 2013
Nikon coolpix l110
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
8/2/2013 2:15:35 PM • Fuji FinePix... • Answered on Aug 02, 2013
2answers
It Isn't Working
I just today sent my camera to Fuji to have the same thing repaired. I've read that the on-off switch tends to fail on this camera.Mine is just a few months past warranty, of course!
this is my 3rd Fuji and 1st problem though.
Good Luck.
3/21/2013 6:48:14 PM • Fuji FinePix... • Answered on Mar 21, 2013
2answers
FinePix S9000
hi, This is actually a very good camera.Did you insert the batteries in reverse accidently?? this seems to be a problem with the switching circuit from battery and power adapter.. did you keep the camera with batteries for a long time with out use?? U can give it to the nearest service to get the circuit checked. all the best my friend.. sreejith
1/21/2012 9:45:50 PM • Fuji FinePix... • Answered on Jan 21, 2012
When i turn on my camera all that happens is a
Possible short within the board and it can relate to a drain on the battery , This can be due to drain on the motherboard due to a short on the motor drive of the shutter. You need to check if this can be a related fault on the board but if you are not equipped it is best to take a consensus with estimation.
10/26/2011 2:24:14 PM • Fuji FinePix... • Answered on Oct 26, 2011
2answers
WHAT IS WRONG WHEN CAMERA IS DEAD? THE BATTERIES
Possible solutions are:
card or battery door tabs for cut out switches are broken or the micro switches are damaged.
Blown fuses on the board. There are several fuses on the main board and power board and to determine which one has blown you can connect an ac adapter to see if your camera will power up via mains. If it does then the fuse for the battery has blown. If neither will power up your camera then the main board fuse will have blown. To check the fuses you will need a service manual, not an owners manual, for the locations and correct types of fuses.
9/14/2011 10:50:13 PM • Fuji FinePix... • Answered on Sep 14, 2011
Command dial on a friend's
Hi. I just bought this exact model on ebay and it arrived with the same problem. I found many others with the same problem on various sites, but happened upon this extremely thoughtful man's album showing the steps to fix it. Thought I'd share with you.......
http://www.flickr.com/photos/jgustavoam/sets/72157603573975379/
8/8/2011 11:21:33 PM • Fuji FinePix... • Answered on Aug 08, 2011
Fuji fin epix Z5 -
If it is in warranty you can get it replaced in Service Center.
5/30/2011 12:28:00 PM • Fuji FinePix... • Answered on May 30, 2011
When I change the batteries
This battery is not user-replaceable. You will have to live with it Im afraid.
3/5/2011 1:03:10 PM • Fuji FinePix... • Answered on Mar 05, 2011
My finepix s9000 will not turn on, it clicks a few
remove the batteries, let it sit for a week or so, then load fresh batteries and it will turn on. Apparantly the auto shut down feature prevent it from turn on until the internal memory is erased. This is a stupid problem that Fuji should fix
1/23/2011 12:54:49 AM • Fuji FinePix... • Answered on Jan 23, 2011
I get green horizontal lines
Are the green lines on the camera while viewing the picture or is it in the pictures once you have saved them on the computer.
Green Line on your view is you LCD. If the pictures comes out alright then it is just bothersome. Good Luck
1/7/2011 6:28:01 AM • Fuji FinePix... • Answered on Jan 07, 2011
0answers
Fuji FinePix S9000 Zoom Digital Camera Logo
38 questions posted
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
FinePix Fuji
  • FinePix Fuji
Most Popular Question
lcd in fujifilm finepix s9000 broken
  • Cameras
