20 Most Recent
Fuji FinePix S5200 / S5600 Digital Camera Questions & Answers
Fuji finepix 5600 white stripes
When you say 'played back', do you mean viewed on the camera screen, or after downloading to your computer ? If the latter, it could be to do with the software you are using - try FastStone.
Fuji finepix S5600 won't take pictures
A possible solution could be found in the menu of the camera. Scroll through the menu and look for any dropdown menu that deals with mode and see if the correct mode is selected.
What is the S5600 long exposure setting
Long exposure means a longer shutter speed, letting light onto the sensor for a longer period of time. This increases the brightness of the image but also will cause motion blur if the camera and subject are not stationary.
Problems with my fuji S3400 camera
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa:
Organize edit and share your photos
Polarizing filter for fujifilm FinePix digital camera A210
I'm not sure you can use a round filter that fits into the mouth of your lens. The manual does not say anything about thread size. But there should always fit a P type filter set. Kood has "cheap" sets. There are a lot of Chinese firms that are in this market. There are lots of other brands and it could be you can buy a filter and holder paying more than your camera is worth. A P-type adapter ring from KOOD is less than $10, and a filter from $30 (46 mm) till almost $100 for 86 MM.
Only if you are making lots of pictures in sun light and you want to have that touch more, you should invest in polarising filters, because they are very expensive. For your digital camera you only can use circular polarising filters. (That goes with every digital camera)
