20 Most Recent
GoVideo VR4940 DVD Player/VCR Questions & Answers
Magnavox dv220mw9 the vcr player won't play
Someone will have to open the unit to see what is happening---either tape is not loading all the way or when FF or Rewind hit not moving the reels----could be as simple as a belt or a bad drive idler (most use either a rubber wheel or gears to move the tape in Play, FF, and Rewind.
Recorded GoVideo DVD-R will NOT play in any other DVD player
most dvd players have a region code and you must know what code yours is in, oryou can't play any dvd's, try and find your dvd code,by the way you can only change the code ,think it is 5 times , then it will stay in that code and cannot be changed.
The power button comes on-from red to green, It
From your description it is processor controller ic issue, remove the power supply cord from the receptacle and any other cords that are tied to the machine for at least 30 minutes to see if the processor can be set. If this fails it is more cost effective to buy new rather than trying to repair the combo unit.
I have a vr4940.
Hi
Thanks for using FixYa. Locate your DVD player’s manual
Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a
stiff wire—such as a paperclip or safety pin—into the hole. Push gently and the
drawer should open partway. Gently pull the drawer the rest of the way open.
Remove
the DVD and see if there is a problem with it. Most DVD player drawers get
stuck when a DVD is warped or the label is starting to peel. If the DVD is
warped, discard it. If the label is peeling, remove the label.
Steps to
open the DVD player top to remove the CD/DVD manually--
- Unplug the DVD player and
take the outer casing of the DVD player off. This entails either taking
out two or three screws or simply sliding one of the pieces of plastic in
either direction.
- Locate the disc loader cover.
The disc loader cover is located where the extending DVD tray finally
comes to rest within the DVD player. It’s the part that holds the DVD
loader in place.
- Bend the two tabs outward
that hold the loader in place. This is a delicate procedure because you
don’t want to hurt the device. The tabs are relatively easy to break since
they're plastic in most cases.
- Slide the disc tray out. If
your disc got stuck before it was read, it's probably still on this tray.
If so, your problem is solved. However, if the disc was fully set and
loaded, the job isn’t quite finished yet.
- Move the small mechanical arm
that holds the disc in place over so that the disc and the reader are both
exposed. Some DVD players will not have anything holding the disc in
place. Instead, these devices use a system not unlike that of a common DVD
case. The DVD will be locked in place in the center.
- Carefully lift the disc up
and out of its loaded position in the DVD player. This may entail sliding
the disc reading mechanism over slightly. This won't hurt the device as
long as you’re careful. You should be able to access and remove the disc.
Points to
remember while performing above steps---
n
Before
you remove the DVD player cover, try turning the device off and then back on to
see if the disc will come out after the machine has rebooted.
n
Use
the opportunity while you have the outer casing off to clean the lens of your
DVD player.
n
Never
work on an electrical device that's still plugged in.
n
Opening
a DVD player may negate the warranty. Read yours carefully before you proceed.
Please do accept the solution if the issue is
resolved else revert for further assistance.
Thanks
Rylee
UNABLE TO READ DISC
try some more different disc.also check out the disc in another player.if the disc are working in another player that means the disc are proper but the lens in the player is either got faulty or dust is got collected on the lens glass.get the lens cleaning cd from the local electronics computer shop and insert in the player and try inserting the cd if same error that means the lens is got faulty and needs replacement.
thanks.
VCR plays audio but no video
audio heads and video heads are seperate on VCR"s.....the video head might be extremely dirty and not able to pick up information from the tape..this requires major cleaning...manually..not with cleaning tapes....the guides might need to be re-adjusted..mechanically....or worst case is the little ferrite beads of the pick up heads on the video cylinder are no longer there, have broken off. in any case, the machine needs to be opened for service....cleaning the heads manually, you can do yourself with some paper such as note pad paper and acetone. acetone cleans very well, you spin the cylinder by hand while holding the acetone soaked paper against the heads. you might need to repeat this a few times with fresh paper depending on how much dirt comes off....good luck
silvio
Go Video put an 800
I was wondering witch model you had? You can go to this site for further instructions: http://www.devicemanuals.com/guide/DVD%20Recorder/GoVideo-manuals.html
You may have to download ConvertX to DVD for the discs to play in other dvd players.
Go Video's website is here: http://www.goovideo.com/?contact
How do you use the
The Go Video VR 4940 can only record to DVD -R and DVD -RW discs. It cannot record to +R or +RW discs. It can play back many types of discs, but can only record to the -R and -RW ones.
JFFields
Programming the vcr
you need to use the remote control...go to the setup button upper right corner of the circular ring...menu shows clock...use arrows on the ring to highlight and in and out with the horizontal
arrows..select manual and set date and time..for channels you have to select scan for channels..and
delete unneeded channels..good luck..
GoVideo VR4940
try unplugging unit for a while and restart it..as far as replacing it ..it would be easier to get an external unit instead..cheaper too...
DVD/VCR combo says every dvd is unreadable
try unplugging the unit for a few minutes..region 2 doesn't work on older dvd players/recorders..the newer ones may handle it...try the computer...and see if that can play it...
