20 Most Recent
Maytag MMV5156AAS Microwave Oven Questions & Answers
It will run but it won't heat. It also makes a
Sorry to read about your problem, I hope this helps you out.
you may one of these issues.
- Blown fuse in HV transformer primary circuit or HV fuse (if used).
- Bad connections (particularly to magnetron filament).
- Open thermal protector or thermal fuse.
- Open HV capacitor, HV diode, HV transformer, or magnetron filament.
- Shorted HV diode, HV capacitor (will blow a fuse), or magnetron.
- Damaged protective VDR from filament to chassis (not commonly used).
- Defective HV relay (not commonly used).
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
5/3/2016 11:49:55 PM •
Maytag...
Answered
on May 03, 2016
Maytag mmv5156aas microwave
That's a classic sign of a bad turntable motor.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
7/20/2013 11:57:55 PM •
Maytag...
Answered
on Jul 20, 2013
My problem is the handle
To remove the handle, you will be needing a flat-head screwdriver and Phillips screwdriver.
Having got the above tools, follow the instructions below:
Step 1:
Disconnect power to the microwave. Simply unplug from the wall or turn off the breaker in your fuse box.
Step 2:
Open the microwave door. With the flat-head screwdriver, pry off the plastic panel from the inside of the door. Be careful not to break the panel in the process. The two screws securing the door handle to the microwave are located behind this panel.
Step 3:
Unscrew the two screws securing the door handle, then remove the handle.
Align the screw holes on the new door handle to the screw holes on the
door, then insert the screws and secure the new handle.
Step 4:
Snap back the plastic panel into place, then restore power to the microwave.
Make sure you follow the above instructions closely, and you won't have any problem.
For further assistance, please let me know:
Regards.
9/15/2011 4:30:51 PM •
Maytag...
Answered
on Sep 15, 2011
Need to replace the glass
The part number for a replacement carousel tray for the model number you have listed is: AP3038395 and can be ordered at appliancepartspros.com. The tray is listed as item 14 under the "Internal Controls" parts list. Some other sites you might try for cost comparison:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
If you have any questions, please let me know. I hope this helps you.
4/12/2011 12:56:10 PM •
Maytag...
Answered
on Apr 12, 2011
How high should the bottom
I would say at a reasonable safe height. There is no requirement by the machine governing that measurement.
3/24/2011 2:57:10 PM •
Maytag...
Answered
on Mar 24, 2011
When i start my microwave
You perhaps have too many large appliances running on one particular circuit. Try unplugging everything you aren't using (coffee maker, toaster, etc) and if that doesn't work, I would suggest contacting an electrician to evaluate the circuits in your kitchen. You could also replace high wattage appliances for smaller ones, say a 750W microwave,
3/5/2011 8:04:44 PM •
Maytag...
Answered
on Mar 05, 2011
MICROWAVE CONTROLS WORK, AND THE TRAY TURNS, BUT
CHECK OR LOOK FOR SOME ONE TO CHECK THE POWER TRANSFORMER IN YOUR MICROWAVE.IF DO NOT PROVIDE THE VOLT OUTPUT YOU NEED A NEW TRANFOMER AND CHECK FOR BAD CAPACITOR ON POWER SUPPLY.
2/18/2011 5:07:10 AM •
Maytag...
Answered
on Feb 18, 2011
NEED A MANUEL FOR THIS MICROWAVE
Go to managemyhome.com and click on the "Manuals" link at the top of the page. Enter your model number and your manuals are available in a .pdf (Adobe) format. You can download a copy or print for FREE. I hope this helps you.
2/1/2011 4:08:38 AM •
Maytag...
Answered
on Feb 01, 2011
Maytag Model MMC5000BDB microwave, clock works but
It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it.
YOUR
SAFETY IS PARAMOUNT
This is a job for a professional but if
you are safety clued up, here's instruction.
Make sure the
!!!!capacitor is discharged!!!!! before attempting any
sort of repair.
Check the door interlock switches first then the
high voltage diode with either an AVO model 8 or moving coil meter on
high resistance range for short circuit, (DVM's won't show the
fault!), the capacitor can fail and go short circuit, the feed fuse
on the primary of the high voltage transformer and then finally, the
magnetron is best checked by substitution.
Hope that helps.
Load
test.
A
simple safety test.
Place 1/2 litre of water in a glass container.
Measure the temperature of the water.
Place in microwave and heat
on full power for 1minute.
Measure the temperature after it has
stood for 1minute.
If the temperature difference is more than 9
degrees Celcuis the magnetron is working and producing about 700Watts
of heat.
If your microwave is labelled with 900 or 1000Watts. That
is about right.
If the temperature is less then the magnetron is
not working properly and may need replacing.
This
a only a rough guide and any doubts you should consult an authorised
service agent.
1/19/2011 8:44:31 PM •
Maytag...
Answered
on Jan 19, 2011
Need a manual
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, and a list
of Dealers for spare parts, as required.
Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge.
I
hope this helps.
12/29/2010 5:57:54 PM •
Maytag...
Answered
on Dec 29, 2010
The blower and the light does not work.
the light is simple take the back of and rplace the globe as for the fan i have looked a t the scematic and i cant see that it runs in line with the globe but it might meaning ounce the globe is fixed the poer will pass through it to the fan if the globe is replaced and the fan does not come on then you have a fault in line to it and it will need further investigation
best of luck happy christmas
please remember to rank my advice
12/2/2010 6:09:52 AM •
Maytag...
Answered
on Dec 02, 2010
Will run, but wont heat..
The magnetron is what makes a microwave heat. The megnatron can go bad causing no heat but let the rest of the unit work just fine.
partselect,com and daysappliance are excellent sites for parts, prices, diagrams, and more.
11/10/2010 8:13:58 PM •
Maytag...
Answered
on Nov 10, 2010
