20 Most Recent Wave Industries OLY-OL3000 Globe Phone Questions & Answers
Noise? Louder than normal motor noise? The display is created by the revolving LED board that is connected to a motor. It should be quiet unless you pick it up and give a good listen. Let me assume that you mean that it is normal noise, indicating that the unit is turning. Unplug the power as well as the phone lines from the unit. First, remove the plastic globe. There are 4 points that the globe is connected, two towards the rear and two in front on either side of the control buttons. Press the globe at the front ones and lift towards the rear. After you have removed the globe, remove the three screws that hold the rotor (looks like an "L") to the motor shaft. The LED display is soldered to the rotor. These solder joints break and need to be re-soldered. By adding a small amount of heat as you are bending the display slightly inward, you can repair the connections. Only use low watt solder gun! Re-attach the rotor and globe (unit will not spin with globe off) re-connect the power, press the select button and check out the display. If all connections were made, you will have succeeded. If a line or two are missing, try again!
Wave Industries... | Answered on Nov 20, 2013
Prevent global warming? It is already among us!
If you mean to reduce global warming, then I would answer "Reduce your carbon and greenhouse gas emissions."
Wave Industries... | Answered on Sep 09, 2011
try unpluging the unit, remove the batteries and replace them, disconnect the phone lines and wait before about five minutes and do a fresh hook up. Do everything you did when you first bought it. If it still won't display then you unit may have fallen and the leds connections could have been dislodged.
I hope your unit reboots. I have a Discovery Channel Blue Globe.
Wave Industries... | Answered on May 25, 2011
Try Ebay, but they can get expensive.
Wave Industries... | Answered on Jan 19, 2011
I want to either buy or repair a blue info globe
Wave Industries... | Answered on Jan 02, 2011
Jesse,
When lightning storm hits anything it burns the equipment either completely or partially. In your case it seems the latter. Partial damage. Open it up and look inside. Can you see any brown outs or do you smell some burns??? Need repairs.
Wave Industries... | Answered on Jan 12, 2010
This should help out.  You need adobe acrobat to view it.
http://www.smarthome.com/manuals/5109.pdf
Wave Industries... | Answered on Aug 25, 2009
It is always safe to remove once it is done. You have cut off circuit in your device but over exposure may weaken the circuit. Please rate me if you lik this!!
Wave Industries... | Answered on Aug 17, 2009
try going to your phone settings and go to calling settings you should be able to disable and enable it there.
Wave Industries... | Answered on Jul 28, 2009
pl;s explain me which problewm u face wih email
Wave Industries... | Answered on May 04, 2009
check amazon.com olympia OL3000 scroll down to product product details
click product manual pdf can print from there g l
Wave Industries... | Answered on Mar 05, 2009
Funny that I came across this. I just now fixed this exact problem. This unit had failed after an electrical storm. Solution found elsewhere suggested removing the batteries and unplugging the A/C adapter for 10 minutes. (I waited 30). Reinstall batteries and reattach A/C adapter. Buttons worked to get to the erase memory option, which I did. Infoglobe is now functioning properly. This is also the instructions for clearing the "eeprom error" readout that many infoglobes exhibit after a power surge. Good Luck!
Wave Industries... | Answered on Feb 22, 2009
If you're into punishment, it looks like Sharper Image has one for $50.
You might want to call first (317) 574-9250
Carl
Wave Industries... | Answered on Dec 02, 2008
Yes. The problem is broken connections where the LED board is soldered to the rotor board. Feel free to e-mail me for more help derby503@cox.net
If you can solder with a fine solder gun you can fix the problem!
Wave Industries... | Answered on Oct 01, 2008
Wave Industries OLY-OL3000 Globe Phone Logo
38 questions posted
Top Wave Industries Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Wave Industries Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Wave Industries Lands Phones
Most Popular Question
infoglo stopped displaying
  • Lands Phones
