20 Most Recent
LG DLG8388 Dryer Questions & Answers
How do i troubleshoot a door open error on lg dryer?
The door switch might be bad or, out of alignment or, "gunked up". The sensor wire to the door switch might have come loose or broken - check the continuity of the wires (Ohme them from end to end). The switch can be checked the same way - by ohming it. See if the resistance changes as you open and close the switch.
LG DLG8388WM won't heat ...
It could be a clog in the supply pipes inside the dryer itself or a faulty regulator your best bet it to find a local repair shop as dealing with any gas appliance without proper knowledge can destroy your appliance or worse you PS: do you smell gas when it runs if so then it could be the igniter is faulty!
Leaking water
Make sure your vent tube on the dryer going outside is clean the entire length and the outside door/loovers are free
Lg dryer dlg8388 , with
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this
gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis
electric no heat tip...
heatman101[
I have have a 2007
there is a chance that one of your hi limit thermal fuses has gone bad.
they are located in side the dryer cabinet. usually the one that goes bad is the one attached to the flame tunnel.you need to check the continuity of all your thermal fuse as well as the ignitor replace what you find as bad
LG Dryer won't start beeps twice, it's brand new.
Two beeps is typical door not closed. Make sure the light goes out when you close the door.
Otherwise make sure both Clean Filter and Flow Sense lamps are off.
You can run the installation test. See following URL.
https://www.lg.com/us/support/help-library/how-to-run-and-installationheat-test-on-an-lg-dryer-CT10000011-20152714315153
6/23/2023 2:41:11 PM •
LG Dryers
Answered
on Jun 23, 2023
