20 Most Recent
LG Goldstar 30-Pint Dehumidifier Questions & Answers
I love this dehumidifier, but
Terry, the hose connection should be on the rear of the uni, covered by a screw off cap. The hose can be not longer than 48" and should slope down and straight to the floor drain. As, proper drainage relies entirely on gravity.
Hope this helped you and thanks for choosing FixYa.
Dehumidifier
Contact the people you bought it from and have it dealt with under warranty. Doesnt sound like a minor problem. Hope this helps.
LG LD450EAL no power
Try resetting the GFI breaker, assuming it is connected to one. Also check the main breaker panel to make sure the breaker is not tripped. Unfortunately the electronic panels do go bad in these systems after a few years of service. Try resetting the unit. There should be a tiny reset button on the back. Also if the bucket is full it will not turn on, make sure it is in place and seated properly or it will not turn on. There may be a reset on the cord itself as well, hope this helps.
