20 Most Recent
LG VERIZON VX5200 Hands-Free Headset (Silver) 98323 / AAYN4264A / 22802H Headset Questions & Answers
I help me with an LG network unlocking code
the default is always one of these code try them all the last four digits of the phonenumber last programmed in the phone aka your number or 9999,1234,4321,0000,1111 if none of those work you can go the retail store for a flash they hook it to the computer and push software to the phone to correct the issue it takes five mins and its free its a common issue for them to correct if you change your lock code from the default in the future always set up a dummy contact with it in there so that you can easily look it up also please vote for me I'm trying to work my way up to expert level and I cant without your vote please
Upon starting up phone;red strip at bottom
you should be able to press one of the buttons under the word unlock to unlock it then to program it you will need to pair it the phone the phone has a bluetooth menu which will say discoverable or something to that effect visible press it then put the hands free in pairing mode by pressing the button under pair or sometimes holding down the button til it says to pair or gives a strange series of beeps depending on the model then on phone hit serach for devices and thenit will ask for a password on both type 0000 and then its set up you can toggle on and off through the hands free option in your phones menu or if by any chance it gives a dial pad dial *228
Toilet ooopsie
http://www.fixya.com/support/r3771170-phone_water_damage
Lg voyager unlock codes
On the EnV, dial *228 and select option 3. This is a relatively new feature which allows you to switch handsets anytime you wish. Follow the directions and you should be able to deativate the EnV and activate the Voyager.
Unluck stolin voyager
i found a voyager and i cant unlock it send me the hidden code that unlocks the phone please i know the code for atnt and tmobile but not verizon
Dropped cell and people cant hear me
I had the same problem as the person in the original posting -- I dropped my phone after which callers could no longer here me. So I tried dropping the phone again, as the original poster suggested, and afterwards the problem was solved.
Phone frozen
i took mine to a verizon store...they wanted me to buy a new phone
Urgent
try the last 4 digits of your phone number.....this should work.
Lock code
ill tell you what to do if you go buy me a verizon prepaid card
Cell Phone Issue
Take a piece of metal like a bobby pin and rub it on the bottom of the phone where you plug the charger in. This will reset the phone. It work for me and saved me from buying a new phone.
Good luck!!!!!!!!!
Car kit
there is internal damage an easy fix is to plug it into the car charger and it will only work on the charger you should have let the phone sit out and dry with the battery detatched. my phone did the same thing about 3 months ago. if that doesn't work you'll need a new phone
LG Verizon Chocolate Phone headset issues.
They have different music kits for different phones. You may have gotten the wrong kit from the verizon people. You might want to go back there and ask them if you have the correct kit.
On LG tone infinim hbs900 I have a blinking blue light but won't pair to my Apple iPad ?
If the LG Tone Infinim HBS900 is not pairing with your Apple iPad, there are a few things you can try to troubleshoot the issue:
- Check the Bluetooth settings: Make sure that Bluetooth is turned on and that the LG Tone Infinim HBS900 is in pairing mode. To put the device in pairing mode, press and hold the power button until the LED light flashes blue and red.
- Check for software updates: Make sure that your iPad has the latest software updates installed.
- Check for other connected devices: Make sure that the LG Tone Infinim HBS900 is not already connected to another device. If it is, disconnect it from that device before trying to connect it to the iPad.
- Check the distance: Make sure that the LG Tone Infinim HBS900 and the iPad are within close proximity to each other. Bluetooth devices typically have a range of around 30 feet.
- Reset the LG Tone Infinim HBS900: Hold down the power button for 10 seconds, release, and then hold it down again for another 10 seconds.
- Reset the iPad's network settings: Go to Settings > General > Reset > Reset Network Settings.
- Check if the device is in pairing mode, if not activate it.
If none of the above steps resolve the issue, you may need to contact the manufacturer or a professional technician for further assistance. It's recommended to check the user manual of your device before trying any of the above steps, as the process of troubleshooting the pairing process can vary depending on the model and manufacturer.
1/28/2023 12:39:52 AM •
LG Radio...
Answered
on Jan 28, 2023
