20 Most Recent Nikon N55 35mm Film Camera Questions & Answers
N55 Shutter Problem
If the shutter blades get bent they are hard to straighten out. Better to find a local repairman or you could do more damage to the shutter. Sorry to be the bearer of bad news.
9/17/2017 10:10:50 PM • Nikon N55 35mm... • Answered on Sep 17, 2017
manual
When I turn on my camera an F-- shows up on the
This indicates that the camera cannot communicate with the lens. Older lenses don't have the electronics to communicate with the camera, and you have to switch the camera to the Manual exposure mode. If the lens does have the electronics, then try cleaning the electrical contacts on the back of the lens and in the mount on the body.
3/17/2011 7:22:20 PM • Nikon N55 35mm... • Answered on Mar 17, 2011
Blinking "F - -"
You haven't said which lens you have this fault with, but if it's a "G" model which lacks an aperture ring then the error means that the camera to body contacts are poorly seated. Removing and refitting the lens usually cures it and it's usually caused by the cheap poor construction quality of many of the G's.
5/23/2010 11:02:00 PM • Nikon N55 35mm... • Answered on May 23, 2010
Need the owners manual for nikon n55 film camera
You can download one from http://www.butkus.org/chinon/nikon.htm
3/3/2010 8:41:00 PM • Nikon N55 35mm... • Answered on Mar 03, 2010
I need a nikon n55 instruction manual
You can download a manual from http://www.butkus.org/chinon/nikon.htm
1/27/2010 4:21:00 AM • Nikon N55 35mm... • Answered on Jan 27, 2010
Problem with nikon n55
What lens are you using? Do you have other lenses you can try?
The F-- indicates that the camera and the lens are not communicating. There are several reasons for this:
1. The lens is not electronic. All lenses before the advent of autofocus fall into this category, as well as some of the newer ones. The only way these lenses can be used is in Manual (M) mode, without any assistance from the camera's light meter.
2. The lens has a locking aperture ring. In this case turn the aperture ring to the smallest aperture (largest f/number) and lock it. You control the aperture via the command dial on the camera body.
3. The contacts are dirty. Remove the lens, clean the contacts on the back of the lens and on the mount, then reattach the lens and see what happens.
4. The lens and/or camera body needs service.
1/16/2010 12:43:03 AM • Nikon N55 35mm... • Answered on Jan 16, 2010
Shutter won't open
Bad capacitor. You may not want to have it repaired for it cost so much to have it done
1/1/2010 6:14:30 PM • Nikon N55 35mm... • Answered on Jan 01, 2010
How do i read a light meter on a Nikon N55?
Your camera is either fully automatic or fully manual. In addition it has shutter priority and aperture priority semi-automatic functions. With shutter prior. you pick the shutter speed you prefer and the camera will adjust the aperture. With Aperture prior it works the other way around. The exposure will be always the optimum (decided by the camera program).
You can adjust these automatics with the program dial.
11/4/2009 11:25:33 PM • Nikon N55 35mm... • Answered on Nov 04, 2009
Film advance
no thers no more advanses but you can get them doveloped if there a surtin level
10/28/2009 12:16:51 AM • Nikon N55 35mm... • Answered on Oct 28, 2009
2answers
My nikon n55 is flashing err after installing new film
It could be that your camera doesn't know it's rewound the film already. With the camera turned on, push and hold BOTH manual rewind buttons simultaneously - one near the release button ( +/- ) and the other toward the front of the camera at the lens release button. Try the release button again.
1/3/2009 7:13:42 PM • Nikon N55 35mm... • Answered on Jan 03, 2009
Just need specific info on lens to buy
melody,
nice camera, the 28mm to 80mm lens that came with the camera is a fine light weight lens. if you go to a 200mm or 300mm lens weight might be a problem as the lens mount on the N55 is plastic. not a problem with 28 - 80mm. i would look fore a light 200mm lens. not necessarily nikon
12/11/2008 12:24:30 AM • Nikon N55 35mm... • Answered on Dec 11, 2008
Compatability issue
Curious, Have you tried another AF lens on the N55?
10/2/2008 10:43:09 AM • Nikon N55 35mm... • Answered on Oct 02, 2008
[f--]
I found a notice put out by Nikon, there is a mechanical problem with the Auto focus. U can google it and there is a form to download and print to send in with your camera. The service is free to fix it since it is a manufacturer's defect.
7/11/2008 5:32:47 AM • Nikon N55 35mm... • Answered on Jul 11, 2008
F--
Unlike other cameras that start at frame #1 after loading and count up as the film is used, the N55 advance the film to the last frame during the loading process. When loading is complete, the frame counter stops at the number of available frames on the roll (usually 24 or 36) and counts down as photos are taken. I know it sounds backwards but it actually makes a lot of sense to engineer it this way. After the last photo is taken (displays 1 on the counter), the camera automatically winds the end of the film into the cassette and the counter shows a blinking E. I am assuming that that is what is being displayed and not a blinking F. it it is an F, perhaps there is a problem with the LCD display? If so, it probably isn't worth having it repaired.
7/1/2007 6:04:39 AM • Nikon N55 35mm... • Answered on Jul 01, 2007
My Nikon FM has an issue where every-other time I advance the film the shutter mirror flips up and the shutter goes off. I can actually watch the mirror go up as I'm winding if I take the lens off
It sounds like your Nikon FM may be experiencing a mechanical issue with the shutter mechanism. Here are a few troubleshooting steps you can try:
  1. Inspect the Film Advance Mechanism: Check the film advance lever and mechanism to ensure they are functioning properly. Make sure there are no obstructions or debris interfering with the movement of the advance lever.
  2. Check the Shutter Release Button: Inspect the shutter release button to see if it's sticking or malfunctioning. Sometimes, a stuck or sticky shutter release button can cause the shutter to fire unintentionally.
  3. Examine the Mirror Mechanism: Carefully inspect the mirror mechanism to see if there are any visible signs of damage or misalignment. If the mirror is flipping up unexpectedly, there may be an issue with the mechanism that controls its movement.
  4. Clean and Lubricate: If the camera hasn't been serviced in a while, it's possible that dirt, dust, or dried lubricant may be causing the issue. Consider cleaning the internal components of the camera and applying a small amount of appropriate lubricant to the moving parts (be cautious and follow proper procedures when lubricating a camera).
  5. Seek Professional Repair: If the issue persists after attempting basic troubleshooting, it's advisable to have the camera inspected and repaired by a qualified camera technician. They can diagnose the problem more accurately and perform any necessary repairs or adjustments to restore the camera to proper working condition.
  6. Use a Different Lens: Sometimes, issues with the lens can affect the camera's operation. Try using a different lens to see if the problem persists. If the issue only occurs with a specific lens, there may be a problem with that particular lens.
It's essential to handle the camera with care during troubleshooting, especially when accessing internal components. If you're unsure about performing any repairs or adjustments yourself, it's best to seek professional assistance to avoid causing further damage to the camera.
3/16/2024 9:18:35 AM • Nikon... • Answered on Mar 16, 2024
Test question ~ please delete
11/17/2023 4:59:16 AM • Nikon... • Answered on Nov 17, 2023
My Nikon FE film advance lever is stuck. It does
Have you tried fresh batteries and setting the shutter speed dial to M90 or m250 whichever you have? If this does'nt work you can remove the camera bottom plate and gently pull a lever away from the advance cog. Some times things get out of sync in there. Sorry I can't be more specific but I did this many years ago. Good Luck.
4/8/2022 9:42:31 PM • Nikon... • Answered on Apr 08, 2022
How to replace nikon f3 shutter?
There are youtube videos on this type of repair to DSLR cameras and I dont recommend that you try it unless you have incredible talent for small details and a very clean environment.
6/22/2021 1:55:43 AM • Nikon... • Answered on Jun 22, 2021
My Nikon is coming up with “n1” where the numbers are displayed and the film won’t wind so I can’t remove it, what do I do?
On many cameras, a lens error means the lens is not set to is highest f/stop such as f/16 f/22 and the like. The lens must be put in that mode for the camera so that the camera electronics can auto set the f/stop as needed. First thing I would do is look at the f/stop on lens with manual f/stop settings; such as the Nikon 50mm f/1.8D making sure it is set to the highest f/ number (smallest opening). Remove the lens check the dial. Also, is the battery fully charged? If all that is okay then do the following couple of things; 1. Get yourself a film change bag, they look like a black plastic/rubberish T-shirt. Put the camera in there make sure the bottom is fully closed, put your arms through the sleeves, they have elastic keeping light out. Open the camera carefully remove the film canister then using your fingers rewind the film back into the canister. 2. Okay, you do not have access to a film change bag, easy get a thick blanket or two, go in to a closet, close the door, put a towel at the bottom, cover your camera as best as you can then do the same as if you were using a change bag. Important, make sure you are in a completely dark place without ANY LIGHT working its way through to you. Next, being as your are using film, big congratulations for that, purchase a change bag from Adorama, Amazon, B&HPhoto. Every film shooter should have one. Hope the above helps you.
11/2/2019 6:08:32 PM • Nikon... • Answered on Nov 02, 2019
Nikon N55 35mm Film Camera Logo
Popular Tags
15 questions posted
Top Nikon Photography Experts
Tony Parsons
Tony Parsons
Pallikonda Nisha
Level 1 Expert
Are you a Nikon Photography Expert? Answer questions, earn points and help others
View Most Popular
Nikon Photography
  • Nikon Photography
Most Popular Question
blinking f
  • Photography
