20 Most Recent Ruud UAKA018 Air Conditioner Questions & Answers
CANNOT LOCATE FILTERS ON AC
Usually the filter is inside the heater housing. You remove the heater access door which should have a safety switch that opens when you remove the panel, thereby removing power from the electrical system on your unit. The filter, if there is one will be below the fan motor on an upflow heater.You should be able to see the filter when you open the heater access panel.
There should also be a filter in your return air duct or at the grille. The sizes of the filters are usually on the side of the filters.
If this helped you please take the time to write a short testimonial.
8/4/2011 4:04:43 AM • Ruud UAKA018 Air... • Answered on Aug 04, 2011
I have a bad 1.5 compressor in the RUUD outside
it sould just check the orife sice in the a coil and dont mix refrigernts
9/8/2010 1:38:30 AM • Ruud UAKA018 Air... • Answered on Sep 08, 2010
My ac unit won't turn on. a couple of nights ago,
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
8/31/2010 3:25:21 AM • Ruud UAKA018 Air... • Answered on Aug 31, 2010
The air conditioner was working today i have a
Hi, your problem is in the unit outside. Check to see if the fan is on, make sure the compressor is running also. If nothing is on, check the breaker to see if it tripped. Also, the box at the unit has 2- fuses inside behind the plastic cover you can't see unless you remove it. If the unit is off and the breaker was ok, remove the cover and replace BOTH fuses. Do all of this and let me know. If the breaker keeps tripping or blowing fuses if the unit was off, you have a componant shorted. It may be off or on and not cooling well due to a loss of freon. If it is on, hold your hand above the fan to feel the air. It should be nice and warm almost hot if its hot outside. Let me know what you find please. We can find the problem.
Sincerely,
Shastalaker7
6/12/2010 1:26:19 AM • Ruud UAKA018 Air... • Answered on Jun 12, 2010
RUUD Silhouette II UGLH-15EARJR not always coming on
It sounds like there may be an issue with the ignition system of your RUUD Silhouette II UGLH-15EARJR furnace. Based on your description, it appears that the furnace is not always coming on correctly. The blower comes on, but after 30 seconds, you hear a click, and the far-right flame comes on, but it goes out after 5 seconds. Eventually, throughout the day, all the flames come on, but they don't come on the first time. This problem could be caused by several issues, including a malfunctioning ignition system, a problem with the flame sensor, a dirty or clogged burner, or a problem with the gas valve. To troubleshoot this issue, I would recommend checking the following:
  • Check the flame sensor and make sure it's clean and properly aligned with the flame
  • Check the burner and make sure it's clean and free of debris
  • Check the gas valve, it could be stuck closed or malfunctioning
  • Check the thermocouple, it could be faulty
  • Check the control module, it could be malfunctioning
It's important to note that gas appliances are complex systems that require specialized knowledge and skills to troubleshoot and fix. If you are not comfortable working on these issues, it's best to call for professional help, as it may require specialized knowledge and skills to troubleshoot and fix the problem.
1/18/2023 3:28:47 PM • Ruud Heating &... • Answered on Jan 18, 2023
Ruud standing pilot furnace burners won't ignite?
You need to clean the pilot its blocked when it burns yellow .No heat in it.
1/15/2023 9:10:10 PM • Ruud Heating &... • Answered on Jan 15, 2023
Ruud silouette furnace model number UGLJ-07EAUER had the control board replaced 24 hrs later the blower does not kick off once runs continuously.
Your fitter didn't fix the original issue it would seem. That is the problem with fitters, they cannot repair things.
11/16/2022 8:10:48 AM • Ruud Heating &... • Answered on Nov 16, 2022
Where is the pilot light for RUUD Furnace model UGAC-045C
The pilot light for RUUD Furnace model UGAC-045CJB is located on the control panel.
11/5/2022 12:56:30 PM • Ruud Heating &... • Answered on Nov 05, 2022
My Ruud Achiever 90 Plus MDL: UGRA-09EZAJS is 17 years old. Runs fine but wonder if I should replace the blower motor and go to a variable speed motor
The variable speed DC motors you describe do use less power but cost 14 times more too, not worth it especially with you motor running!
10/23/2022 10:17:34 PM • Ruud Heating &... • Answered on Oct 23, 2022
2answers
Electricity dropped momentarily; AC no longer cools
Open the main breaker for 5 minutes and see if the unit resets. Momentary power fluctuations can cause odd behavior, especially in older units. This could also have been the final jolt that killed a failing capacitor.
9/17/2022 3:01:26 AM • Ruud Heating &... • Answered on Sep 17, 2022
RUUD AC, what dual round capacitor do I need?
Check out the link. replace by shape and contacts. https://www.google.com/search?q=RUUD+Achiever+10%2C+replacement+capacitor Compressor https://www.google.com/search?q=copeland+zr34k1-pfv-230+capacitor Fan Capacitor https://www.google.com/search?q=Emerson+Model+K55HXJKL-2918+capacitor Or contact Rudd direct, we aren't they
Capacitors - Ruud Replacement Parts
https://parts.ruud.com > category > ru-capacitors Dual Oval Capacitor - 55/10 uF, 440 VAC, 1.970 x 3.670 x 5.750 (max.) in. .....
8/9/2022 5:29:16 PM • Ruud Heating &... • Answered on Aug 09, 2022
3answers
Help me replace Ruud Achiever 12 contactor?
https://homesteady.com/how-8185688-replace-ruud-ac-contactor.html
8/5/2022 9:29:40 PM • Ruud Heating &... • Answered on Aug 05, 2022
Have old Ruud heat pump 10 seer model # UPKA-031JAZ serial #6389 & my start capacitor has stopped doin it's job. What is the replacement part number please
You can get an aftermarket replacement as long as the ratings are the same. I keep a spare for my unit and its saved me several times over the years.
As to your question, it looks like the part number is 43-23204-04. Looks like several options for those specs on Amazon.
7/25/2022 8:37:32 PM • Ruud Heating &... • Answered on Jul 25, 2022
2answers
I got no nameplate info on an older RUUD system late 1990's and blower motor is not working also specs are not readable. How do I know what size motor to use?
First off how do you know the motor is bad? Have you checked for voltage, the capacitor, the relay? The motor itself will have a data plate telling you horsepower/voltage/rpm/shaft size.
6/26/2022 6:47:02 PM • Ruud Heating &... • Answered on Jun 26, 2022
Ruud Ultra U96V furnace that won't shut off
have you checked and tested the relay for overheating or sticking on when the problem occurs
4/19/2022 12:35:29 AM • Ruud Heating &... • Answered on Apr 19, 2022
Ruud UAKA018 Air Conditioner Logo
5 questions posted
Top Ruud Heating & Cooling Experts
john h
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Ruud Heating & Cooling
Most Popular Question
bad 1 5 compressor in ruud outside
  • Heating & Cooling
