20 Most Recent
Pentax Optio 50L Digital Camera Questions & Answers
I accidently erased my photos and want to undelete
If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos.
This blog article reviews and outlines several of the better ones.
About lens
What about the lens? it's a 5.4-16.2mm f/2.8-4.8 lens.
The problem is it can not read memory card and also can not function with out
TRANSFERRING PHOTOS TO COMPUTERIf your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
When i take pictures it
Rotate the mode dial to the setup mode (screwdriver and wrench) and turn the camera on. Use cursor-left/right to select Set-up2. Use cursor-up/down to select the third item (speech bubble) and press the OK button. Select the desired language and press OK.
Got a pentax optio 50L
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as the free Picasa ( http://picasa.google.com ).
I have lost my cdrom
Don't connect your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
How do i get rid
Enter the playback mode and choose the image you want to "unprotect".
Press the button with the key icon
select unprotect
Press the OK button
Lens error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
Hope
the advise is useful.
Regards
Andrea
Give me a driver
sometimes some appliances don't work with new OS's ....there's no solution
sorry!
I have a pentax optio 50l and when i turn on the
Usually "lens error" means that the lens can't be telescoped out, and it's not a good sign. You'll probably need to send the unit to tech repair.
If the unit does not make any noise at all, it could just be a loose motor connector (but it could just as well be a fritzed motherboard or a dead coil in the motor - which would require a unit replacement).
It could also mean that the internal electronics got stunned or the battery pack hasn't enough juice. So, before trying anything else, get a fully powered battery pack (or external power supply) and retry after leaving the camera "cold" with no battery for a couple of minutes.
If possible, try getting a battery with a slight overvoltage (e.g., replace rechargeable batteries with nonrechargeable ones, just this once).
If there is a grinding noise reminding of plastic cobs snapping together, that's probably exactly what it sounds like - the drive train of the lens broke, and again you'll have to get it replaced.
A very short grinding noise, immediately aborted, could mean you get incredibly lucky - there's a grain of sand or something like that in the telescope, and is wedged hard enough to immediately stop operations before the drive train gets damaged. Try looking with a strong light between the "rings" that make up the telescoping lens, and inspect the outside of the rings (if possible) for scratches. If the obstacle is visible you might be able to dislodge it with a hard plastic sheet (those used in OHP) used edgewise. Also try blowing air in the ring gaps.
You could also try to "help" the drive train by GENTLY pulling on the lens and pressing the power button, or keep the shutter button pressed while powering on (this should run the autofocus retraining and lens extension together).
This happened to me often on Casio cameras which are really good, but have the "rings" not packed close together enough, so that unless you keep them with great care, dirt will find a way to wedge in.
Cant upload photos, computer doesn't recognize camera
a.keep the camera switched on (no stand by ; check the batteries) and plugged to your PC
b.put the drivers cd in the cdrom drive and launch the installation
c.nevermind getting an error message, reboot your PC the usual way
d.when your desktop appears check if you see a balloon tip describing the installation of the camera
e.if not, unplug the camera, wait some seconds and plug it again
f.check if you see a balloon tip describing the installation of the camera
g.if not, repeat the procedure until at reboot the ballon tip shows a successful installation and the camera appears in your windows harware list
it "finally" worked for me under XP, though I still have an aditionnal problem with the "video capture device" not installing :-( (setup.exe from the cd failing...)
