20 Most Recent Pentax Optio T10 Digital Camera Questions & Answers
9answers
How to recover the deleted photos
Hello, Hani kokkoho! You need some photo recovery software (also recover audio and video files); it can help you recover your lost Olympic photos from your Digital Camera: Photo Recovery for Windows Users Photo Recovery for Mac Users Remember not write any thing to the device until you have got your photos back!Best wishes!
2/15/2016 6:09:07 AM • Pentax Optio T10... • Answered on Feb 15, 2016
manual
2answers
Pentax Optio T10 turning off immediately
My optio t10 did basically the same thing...turned on, lens goes out, then automatically shut off. I took the advice of a solution listed here for another problem...hit the camera. For whatever reason it worked.
10/12/2012 9:42:57 PM • Pentax Optio T10... • Answered on Oct 12, 2012
Pentax Optio T10 batteryclip broken
This is a very common problem with this model because the part is made of plastic. Unfortunately the camera must be disassembled in order to replace the part and I know the local service center in New York, Photo Tech is good at this. If the camera is still under warranty then you can either ship directly to Pentax located in Colorado or try the service center in New York. I suggest you contact them at www.phototech.com to find out price and turn around time for the repair.
Good Luck,
Paul
6/30/2011 9:56:05 PM • Pentax Optio T10... • Answered on Jun 30, 2011
Pentax Optio T10,comes up with
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
4/23/2011 4:38:11 PM • Pentax Optio T10... • Answered on Apr 23, 2011
Ive posted for assitance twice. is this a scam?
what is your question?
12/13/2010 11:00:20 PM • Pentax Optio T10... • Answered on Dec 13, 2010
When camera turns on, it
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
8/14/2010 5:19:56 AM • Pentax Optio T10... • Answered on Aug 14, 2010
Pentax Optio a10 turns off automatically after I turn it on
It sounds like you may have a bad lens assembly. If it is sticking, it will buzz. If it fails to open all the way, it will turn itself back off. This is what it sounds like you are saying. I can fix this for $40, or you can send it to Pentax in Arizona. I don't know what they charge for a lens assembly, but the minimum charge for this camera seems to be about $90. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Contact me at: mrfixitmark at comcast dot net
6/21/2010 9:10:18 PM • Pentax Optio T10... • Answered on Jun 21, 2010
Camer will not flash and take pictures every thing
Sounds like a weak or old battery.
6/14/2010 3:51:33 AM • Pentax Optio T10... • Answered on Jun 14, 2010
3 beeps when trying to turn on
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
5/11/2010 10:15:47 PM • Pentax Optio T10... • Answered on May 11, 2010
Pentax Optio t10 says memory card error with brand
camera
4/14/2010 7:29:32 AM • Pentax Optio T10... • Answered on Apr 14, 2010
My pentax optio T10 turns on then turns itself OFF
1/3/2010 5:36:32 AM • Pentax Optio T10... • Answered on Jan 03, 2010
Broken orange battery tab
Contact Pentax and see if they will send you the part, for the tab + S/H it should cost you approximately $25, although I have recently heard they will not provide these items to customers anymore. If they're no longer providing replacements, your device will need to be sent to them for repair (approximately $70 incl labour).
Or... Get a piece of tape and place it over the battery and close the casing, other "ghetto rig solutions" include folding a piece of paper, placing it atop the battery (between the battery and the closing cover) and closing the flap, the paper will hold the battery against the pins and allow function.
12/8/2009 10:31:38 PM • Pentax Optio T10... • Answered on Dec 08, 2009
Cant download pictures to my laptop anymore.help.
Use a card reader to download your pictures to a folder you create on your desktop.
9/28/2009 4:51:59 AM • Pentax Optio T10... • Answered on Sep 28, 2009
Flash stops working
The flash bulb may be broken. Try contacting Pentax to get it fixed.
7/15/2009 5:04:09 AM • Pentax Optio T10... • Answered on Jul 15, 2009
Pentax Optio T10 Digital Camera Logo
Popular Tags
36 questions posted
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
View Most Popular
Optio Pentax
  • Optio Pentax
Most Popular Question
recover deleted photos
  • Cameras
