20 Most Recent
Pentax Optio W10 Digital Camera Questions & Answers
How to unlock card in pentax optio Says Card
Hello
OK, if the memory card itself is locked, you might
sometimes get this error code. All you need to do is to take out the
memory card and switch the lever on the left side to the unlock.
If
the error is still displayed after you did the above, you might want to
try the card in another camera.
If
the card works in another camera . the problem is with your card reader
in your camera.
If you open you sd slot and look inside with a
sharp light , you should be able to see on the left side of the slot
there is a little copper or spring steel lever switch. This switch work
as follows:
1. When no card is inserted / no write protection ,
the switch is open and thus the protection is off.
2. When locked
card is inserted , the tab is depressed and tells the camera that the
card is lock.
Contrary to popular belief ,the little tab on the
sd card is not an electronic switch and does not physically influence
the card operation itself. If you put a locked card into a camera
without a sd lock switch , you would still be able to use the card
normally.
It is incredible difficult to fix this switch because
of space limitations in the sd card. Look into the sd slot and if you
can see the switch , use a needle to pull the little tab down toward the
base of the camera by about 2mm or until it works being careful not to
bend it.
If this does not resolve your problem , there might be a
short in the switch circuit and the camera will need to be disassembled
to resolve this error. This should cost no more than $50.
Please
feel free to contact me if you need further information
Kind
regards
Andrea
Shutter button not working
SD card is only a storage device for data. It has no direct function other than storing pictures. Check your power supply, usually the batteries to see if you have full power. Make certain the batteries are in properly, aligned + to the + post etc.
Check to see if the settings are correct. If all of the above are in order, then the shutter control unit may have malfunctioned and thus Good Bye camera. Not worth the cost of repair.
Lastly, contact the manufacture and ask support for their opinion.
Is there a way to change the settins to Time Stamp the photos on the Pentax W10?
The camera will not deface your photos by scrawling a string of numbers across them. However the date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Hi I have a Pentax
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
I cannot install the software for the camera to my pc.
You don't need to install anything.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as
ACDSee.
Card Locked HP M425
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Can't install the software to my pc.
You don't need to install anything.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as
ACDSee.
Where can I get Free software to download pics from cam ptio w10
You don't need any software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as
Picasa.
Connection of pentax optio m85
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
My Pentax Optio W10 camera takes some out of focus
Your camera has the option for manual focus. This option allows you to focus the camera to capture what you want, rather than the auto-focus feature.
This will be indicated by a MF in the top center of your camera screen. You should be able to change this by finding record mode and changing your AF settings. Change your MF to the [ ] option and you should be on auto-focus settings.
Hope this helps.
Chadlnrd
In certain lighting situations there are spots on
No not dirt, what it's called is lens flare. Lens flare is where a sharp/bright point of light enters the lens on an angle and causes the light to refract through the lens elements. This is hard to see happening on a pocket point and shooter and equally hard to prevent. What can be done is you hold your hand above or to the side of the camera out of it's field of view to cast a shadow on the lens and the flare won't happen. However sometimes you get your hand in the pictures. Even on my pro cameras and lens combination this happens even with the use of a lens hood. The good part of this is I can see it happening through the viewfinder. The only other thing I can suggest is to change either the angle of the camera or recompose the scene or subject to the point of light is not causing this flare.
SD CARD LOCKED
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Card locked
Remove your card from the camera.
Unlock your card shown in the upper figure.
Optio W10 usb cable does nothing
The first rule with any new didital camers is as far as I am concerned is
-Leave The Disk in The Box
Windos is quite capable of reading removeable meadi with out extra layers of programs.
So Remove the software [Start/Comtrol Panel/Add Remove software, etc.,
Reboot the computer.
Plug in the camera
Make sure it is set to the upload function[see manual]
Windows Camera/scanner wizard will come up
select what you want to do[coy to folder]
click OK.
Do all this first
If still in trouble check the cable with another, and if you can remove media card and try through yours PC or another via a card reader.
You have to eliminate which is dud Camera[switchng] cable.
When you have make the decision and concluded it is the camera/cable, pack it all up and take it back from the place it came from.
