20 Most Recent
Olympus SP-320 Digital Camera Questions & Answers
I have a SP
If the lcd you put in is the exact same model ..and it is new..the only issue is from the ribbon ..and I dont think it is a defect ...I think it is just a issue with the plug not being proper inserted or so ...If you can open it ...and same time when it is open ...power it up ..with the ac at least ...( I assume the batteries will not stay in place when the cover is off) and try to see whats wrong with the ribbon plug ..Jiggle a little ...and press it in more ...Until the double image is not there ...take it out again ..blow the dust and so ..and put it back ..but ..find a way to power it up ..and have some kinda image for to have control ..and not be forced to put it back and open it several times...
I want to transfer photos from my camera to a disk
Use the "Backup" option in the card menu. Full instructions are in the "Copying pictures in the internal memory to the card (BACKUP)" section in the advanced manual (page 101 in my copy). If you've misplaced the manual, you can download one from
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1220
A new set of batteries after 3-5 snaps saying Low
- Hi, this can happen due to failure in detecting battery level, (sensor problems) if this case you can use the camera eve though it says low battery,
- in the other case the battery might be low power model, for this you have to check the battery label ( ex:- 2000mAh). see wheather it matches with the original batteries.
- also can happen due to camera malfunction, for example the software or display may be running even when it is turned off.
Brand new batteries will die really fast and we
in some digital cameras when you use lcd screen to take a picture battery consumption is very high, try using the optical veiw finder, also you can use litium batteries which is more expensive than normal alkaline.
there is a new alkaline battery just for digital cameras available in good stores , from energiser
regards
Camera works for a very while, but quickly senses
Something, it sounds like, is draining the batteries. Rechargeables are a lower voltage, and don't last as long as alkalines, but the alkalines should give you at least a couple hundred pics (depending on how much the flash and zoom is used, camera turning on and off, etc.). A camera tech might know the likely cause, but get an estimate before getting it repaired. The cost of service is often more than the replacement cost of a new camera, as they are getting cheaper by the day, almost! Good luck, sorry I can't help any more than that.
Zoom error appears on screen and camera turns off
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
When I turn on the
Base from the description of your problem the lens no longer extended or retract that;s why you're receiving this zoom error and this is a issue with the lens mechanism of the camera.
We can try this turned on the camera while holding in the lens, gears ground a bit and then check if the error will be gone now and if still there this camera lens needs to be service to avoid further damage.
Battery charger
The SP-320 uses standard AA batteries, disposable or rechargeable. If you want to use rechargeables, you should be able to find chargers at any department, electronics, or office-supply store. You can't use the camera itself as a charger, however.
Do I have to use
No you don't. Just has to be the same size. Same amount of pins. If it's and SD card, than any SD card will work, Doesn't matter the brand name of mb size.
LCD panel cracked
The price to have the LCD replaced would probably cost 75% of a new one. If you can do without the LCD and it downloads the pictures to your PC, at least you've got something.
That camera has a viewfinder, so you can still take pictures, right.
Sorry about the bad news.
I can't switch my memory on the Olympus sp320 from
I believe that camera takes a xd card.
Are you using a sd card?
Before inserting or removing a card, make sure the camera is OFF or the data may get corrupted.
After inserting, go to the settings in the camera and format the card. Then select the card as the memory rather than the internal memory.
How do I get the sound to turn on when shooting
Top menu [MODE MENU] [SETUP] [VOLUME)
Press up/down arrow to set the volume, and press OK.
There are 5 levels. Us the highest one.
See page 17 of you "Advanced manual" if you're not sure how to change the volume level.
If above doesn't work, you may have a problem with your speaker
The zoom of my SP-320 is not working anymore. What
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
