20 Most Recent Polaroid i532 Digital Camera Questions & Answers
2answers
The specified memory card is either Toshiba or
The trouble is you've used the internal memory and now your camera is set to use it and not your memory card. You must remove your card, go into the menu and find "format" and follow the on-screen directions to format the internal memory. Then insert your card and promise never to use the internal memory again.
12/24/2013 12:56:24 AM • Polaroid i532... • Answered on Dec 24, 2013
I try to erase photo off my camera and it keeps sa...
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
10/22/2013 6:26:36 PM • Polaroid i532... • Answered on Oct 22, 2013
Polaroid i532 driver downlod windows
You don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa (http://picasa.google.com ).
10/22/2013 6:26:05 PM • Polaroid i532... • Answered on Oct 22, 2013
Need to download the cd
Do you really need the Polaroid software?The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
10/22/2013 6:25:23 PM • Polaroid i532... • Answered on Oct 22, 2013
Need to take close-up detailed
Use the macro mode as described on page 34 of the manual: http://www.fixya.com/support/p443879-polaroid_i532_digital_camera/manual-20448
10/22/2013 6:24:21 PM • Polaroid i532... • Answered on Oct 22, 2013
Unable to transfer pictures form i532 polaroid.
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
10/22/2013 6:21:51 PM • Polaroid i532... • Answered on Oct 22, 2013
How do i download the pictures
10/22/2013 6:21:06 PM • Polaroid i532... • Answered on Oct 22, 2013
Transferring internal memory pictures to a memory card
Use the Copy command to copy the pictures from internal memory to memory card. See page 84 of this manual: http://www.fixya.com/support/p443879-polaroid_i532_digital_camera/manual-20448
10/22/2013 6:18:32 PM • Polaroid i532... • Answered on Oct 22, 2013
Lost installation CD
10/22/2013 6:15:01 PM • Polaroid i532... • Answered on Oct 22, 2013
When camera is turned on card locked comes on
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
10/22/2013 6:13:10 PM • Polaroid i532... • Answered on Oct 22, 2013
manual
Need code to download pictures to computer
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
3/13/2013 2:51:28 AM • Polaroid i532... • Answered on Mar 13, 2013
When I try to load
What software is it you are trying to load. You really shouldn't need anything off of the disc. The camera is plug and play into your computer and if you need any sort of photo software I would recommend downloading picasa, it's free and works great. Download it here:
http://picasa.google.com/#utm_campaign=en&utm_source=en-ha-na-us-bk&utm_medium=ha&utm_term=picasa
Thank you,
Lee
5/30/2011 10:48:26 PM • Polaroid i532... • Answered on May 30, 2011
3answers
How do i upload the
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
3/1/2011 3:07:05 AM • Polaroid i532... • Answered on Mar 01, 2011
Cameras Logo
65 questions posted
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tom Shanks
Tom Shanks
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
View Most Popular
I Polaroid
  • I Polaroid
Most Popular Question
when camera turned
  • Cameras
