20 Most Recent
Polaroid i832 Digital Camera Questions & Answers
Where can I get a cd for my polariod i832 digital
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
CRACKED SCREEN
You cannot repair the broken LCD screen; the white you are seeing is the backlight for it.
LCDs have extremely thin gold deposits along one edge that is contacted by a silicone rubber strip that has fine wires molded into it vertically and one edge is pressed against the LCD panel for contact.
It is a fussy arrangement when new and it sure doesn't get any better when dropped.
I wouldn't delay too long looking for parts or repair; Polaroid filed for bankruptcy last week although I doubt if the parent had anything to do with the manufacture of your camera; as with many companies with limited manufacturing means, the camera was surely built by others.
My software had been corrupted for polaroid i836. how to get software.
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
I am trying to dowload
Having gone over a month without a response to my query, I assume my suggestion to use a card reader solved the problem.
Don't have the cd
Having received no response in over a month to my query, I assume my suggestion to use a card reader solved the problem.
My computer tells me that the camera driver on my
You could use your memory card reader instead of directly connecting the camera to computer. Usually you could find these in many of the laptops. if card reader is not a solution for you, try finding the driver through internet.
Computer won't let me download pics
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
The lens cover is not
this
problem is caused because that the lens servo can`t move the unit of
lens. this menssage mean that the sistem don't go out the lens.
You have to sincronise the mechanism of the lens, carefully disarm the unit and review that the gears are ok....
Thanks.
