20 Most Recent
AEG 23 in. Favorit 44070Vi Built-in Dishwasher Questions & Answers
Favorit 40010 vi dishwasher the machine door opens during the wash except on eco 50 wash
Strange it remains closed on one stage? Usually a door that opens by itself is due to misalignment, and then gain water will leak onto the floor. If someone banged into the side of the door and moved the washer a slight bit, the locking tab under the work counter may not be in a positive position. If the tab is bent slightly up, the door may barely make contact and lock when in operation. A simple movement of the washer could pop the door open. Other than that, any electrical dysfunction would require a professional servicemans attention.
Dishwasher won't drain
If you hear the motor running when it is to be draining you may have a busted pump impeller. Also locate and check the round looking cap it will move up and down by your hand pull it up if it is stuck at the bottom this is your float level it goes up and down with the water level the pump will not switch over if it is stuck on the bottom if it is stuck it is telling the dishwasher it is empty of water. and last but not least your wash timer may be out.
Favorit 44070Vi 3 short warning tones
It is most likely to be the wash pump leaking underneath, the float switch lies underneath the dishwasher, if you tip it back slightly you will probably find that water will leak out, that will prove that it is leaking and it will probably work a couple of times after this but it isn't the answer i'm afraid, a wash pump is not really the sort of thing you should tackle yourself.
Dishwasher cycles normally but water is not
Your input panel needs to be serviced. Please try to change the AC outlet location first before attempting the service yourself. If your still experiencing problems, then remove the front panel to locate the the soldered joints behind the power button. There is a relay which may be worn and can be changed by you. You may find the area covered in rust and oxidized. If this is the case, then we have found the root cause behind your problem and will need to change out the bad part. Please reply with any question
TABLET IS NOT DISSOLVING.HELP
Take off lower spray arm there is a spay hole underneath if its blocked the tablet gets left in the bottom. also check the filter is not split as rercycled food deposits is the cause of the blockage. short programme is not suitable for tablets,
Does not complete a wash cycle
Hi
Thanks for using FixYa. If the cycle doesn't
complete, then the first thing that should be checked is the Timer and then the
heating element. Timers don't often fail. But if every other part of the
dishwasher seems to be working properly and the timer knob seems to be stuck in
one place--doing one function continuously--the timer may be at fault.
Dishwasher timers can't be repaired. If yours is defective, replace it. Many
dishwashers heat the wash and/or rinse water to a higher temperature, as the
cycle calls for it. In these cycles, the dishwasher pauses after it has filled
with water, waiting for the water to reach the pre-set temperature. What
happens next depends, as follows: On some units, the pause is timed and the
unit continues after the allotted time. On others, the cycle can't continue
until the water reaches the higher temperature. If you have this type of
dishwasher and the water isn't being heated (say, because of a problem with the
heating element or thermostat), after the unit stops at the heating cycle, it
never continues. When you repair the heating-system problem, the "cycle
problem" is fixed too. Please do accept the solution if
the issue is resolved or else revert for further assistance.
Thanks
Rylee
I have a aeg 43070 vi dishwasher It keeps
I assume you are refering to the earth leakage circuit breaker. This trips when a earth leak fault has occured. The normal cause for this could be
A) Water leaking via a pipe at the bottom comming in contact with one of the electric motors at the base of the washer.
B) A heating element has gone faulty with a electrical leak to earth.
You need to test this with a multimeter on the OHMS scale and rectify any short to earth that the meter would indicate.
Favorit 43070 vi leak
I assume that this leak is from the flat tank on the side of the machiene. Any water leak to the bottom of the machiene puts the washer in ANTI FLOOD mode with the pump out motor activated. You can remove the flat tank by disconnecting the hoses to it and pulling it upwards. If you find a small leak just run it over with a hot soldering iron to melt closed the small leak. Also note that this tank has a small outlet pipe that deliberatly discharges water to the anti flood device (polystireen float / micro switch at the base of washer) in case of a fault (blocked pipe / leak etc).
The dispenser flap doesn't open
you should check first that power is going to the dispensor at the appropiate part of the cycle.
to get at the dispensor, split the door - its screwed together by screws round the periphery. dispensor is just held in by usually 6 obvious screws
