Our Favorit sensorlogic machine will
What this problem is pointing to, is that the washer have develop a power problem function that will need to be resolve your self as do it your self offer below are the instructions. to follow.
A dishwasher usually operates without any problems. But, ifyour dishwasher won't start, it's easy to get frustrated and think that youneed a new unit. Oftentimes, however, you can easily fix this problem withoutthe assistance of a repair person. You can save money and avoid waiting for aservice technician to repair your dishwasher.
Electricity.
If your dishwasher won't start, see if the power cord fits snugly into theoutlet. Do not use an extension cord. Plug the dishwasher directly into thewall. Test the outlet with another appliance, and see if it's actually live.Check your home circuit breaker or fuses. Turn on the circuit breaker if an appliancehas tripped it. Examine the fuses, and change out any ones that are black orhave broken wires. If your power is turned off, contact your electricitycompany.
Water/Control Panel
You must turn the water shutoff valve to the "On" position. Cleanthe water inlet hoses and filters if they are clogged. Straighten the hose ifit's kinked, or replace it if it's crushed. Depending on your model, you canlock your control panel. Unlock the control panel, or reboot it if you justexperienced a power outage.
Wiring
Check the internal wiring if the dishwasher isn't powering on. Unplug thedishwasher from the power source, and remove the front panel. Examine thewires, especially the main wiring connection. This connection often burns outon older dishwashers. Check the wiring to the timer and the door switch, andthe wiring that runs from the door to the base of the dishwasher. Replace anywires that are corroded or broken. Check the door switch, which is four wires connectedvia a plastic housing. Get a new door switch if any of the wires are burnt out.You probably have to get this part from an authorized parts supplier or themanufacturer.
Door/Motor
You must completely close the dishwasher door for the cycle to start. If youopened the door in the middle of a cycle, push the door closed and press the"Start/Resume" button to restart the cycle. If the door isn'tclosing, check the door gaskets/seals, and clean them if they are dirty. If thegaskets or seals are cracked or falling off, replace them. Your motor may pausebetween different wash cycles. If the motor doesn't restart, it's overloaded.Allow up to 30 minutes for the motor to reset, and then restart the cycle. Ifthe motor is dead, contact a service technician.Thanks.
