20 Most Recent
Nikon Coolpix 3200 Digital Camera Questions & Answers
"Nikon software does not run on this Operating System" Error Message
When attempting to install Nikon Capture or PictureProject on certain Windows 98SE systems the following error messages may present themselves:
This message is caused by the registry key value for the "SubVersionNumber" on the version of Windows. If the system contains SubVersionNumber "B" Nikon Capture and PictureProject will not install on the system. Below are instructions on how to manually edit the System Registry to change the SubVersionNumber Registry Key to allow for Nikon Capture and Picture Project to install.
Manually editing the System Registry requires vigilance and care because a mistake could cause errors with the System. Be extremely careful when editing these keys. Nikon is not responsible for any loss due to problems with registry key editing.
To manually edit the System’s Registry:
1) Quit all running applications
2) Click on "Start" then "Run…" Type the following in the run command line: "regedit"
3) Click "OK" and the registry editor will open
4) Click "Edit" from the menu bar and choose "Find"
5) Type "4.10.2222" into the "Find What:" field
6) Click "Find Next"
The results will appear in the column on the right. The Version Number will be highlighted.
7) Click on "SubVersionNumber" once.
8) Go to "Edit" on the menu bar and choose "Modify"
9) The current Value data will read B.
10) Change "Value data" to " A" (MAKE SURE THERE IS A SPACE BEFORE THE A)
11) Go to "Registry" in the menu bar and choose "Exit"
12) Confirm the change has taken effect. Right-click on "My Computer", choose "Properties".
13) The version value should reflect "4.10.2222 A"
Nikon Capture and Picture Project can now be installed and run on this system.
Camera got wet
You got it wet enough that you had to disassemble it? It's toast dude. Sorry.
Camera is slow
Use a faster SD card. The write speed number is what you look for. The greater the number the better the card.
Battery Problem
I just had this problem today myself, and looked everywhere online for a solution. I changed the batteries (to Panasonic), and it didn't help. But i tried different batteries (Energizers) and the camera started working again.
My battery will not charge
First, you did not say how old the battery is. Rechargeable batteries do not last forever and if left on the shelf for prolonged periods can discharge to the point that the suffer permanent damage and will not take or hold a charge. Most rechargeables last for about three years give or take. It could be that your battery simply needs replacement. You identified your camera as a Coolpix 3200, I presume you mean an S3200.
Start by removing the battery from your camera and making sure that the battery contacts in the camera and on the battery is clean. Dirt and grease can prevent the charging current from flowing to your batteries. If they are dirty. A new pencil eraser can be rubbed against the contacts both in the camera and on the batteries to remove any oils or residue. Next, I would try to charge the battery again.
If that does not work, replace the battery. Your camera takes a model EN-EL19. Since new batteries normally have a partial charge on them, I would first see if the camera will power up and take a picture. If so, the next step is to see If the new battery will charge in your camera. If it does, you have solved your problem. If not, the camera's charging circuit may be at fault. If that is the case, you have two choices. You can send the camera Nikon USA for repair or, if the camera otherwise functions correctly, you can save the cost of repair by purchasing a model MH-66 external battery charger and charging your battery outside the camera.
If you need to send your camera in for repair, you can call Nikon USA Service at 1-800-645-6687 9AM-8PM EST, Monday to Friday for assistance or go to there website (link below). They will give you a free repair estimate if your camera is out of warranty.
Nikon Service and Support Nikon Customer Service Nikon Support
Battery exhausted even after charging.
There are two possibilities. First, rechargeable batteries do not last forever. Take out your rechargeable batteries and replace them with non-rechargeable ones for test purposes. If your camera works ok, it may be that the camera's charger circuit has gone bad. Try charging your batteries on an external charger. If they charge, it is your camera's charger, if they do not hold a charge, it is probably time for new rechargeable batteries.
I am unable to see all the photos on the camera
I can't tell you exactly why all your photos became unavailable on your camera, but I do know that many digital cameras as well as handheld media devices (zunes, sansas etc) are very fussy when it come to the images stored on them. They write index files describing what is stored on them, and yes, if your alter any files using a computer after they were imported and indexed, they will disappear from view on the device. I am surprised that all your photos no longer show up, not just the ones whose orientation was altered.
I recommend moving your photos to your laptop and using your camera to reformat your memory card. I am unaware of any way to coax them into being viewed on your camera once they have been shunned.
Pictures are pink
Did you really drop the camera? because the pink could be caused by a misplaced lens. But you also should check if you did not change the strings to manual. Like manual White balance or scene. Try the camera in the automatic setting. Please check the type number you gave, because Nikon did not make a Coolpix 3200. And I think the S3200 is to new.
Battery exhausted
The manual says:Confirm all connections.Off is selected for Charge by computer in the setup menu.When charging by connecting the camera to a computer, battery charging stops when the camera is turned off.When charging by connecting the camera to a computer, battery charging stops if the computer is suspended (sleeping), and the camera may turn off.Depending upon computer specifications, settings, and status, it may be impossible to charge the battery inserted into the camera via computer connection. So be sure you are charging the correct way. Best way to do is to remove the battery and put it on the charger for a couple of hours. If you have the battery out, you can check all connections of battery and in the camera.In trouble shooting, more than a full page is dedicated only to the battery and the method of charging. The manual is still online, but should also on the CD you got with the camera.
