20 Most Recent Mitsubishi Wd-82837 82" Inch 3d Full Hd 1080p Dlp Hdtv Home Cinema Television Questions & Answers
I have an issue of my car mitsubishi spacegear,,4m40 year 1994..why does A/T blinking at the dashboard??
It sounds like you are experiencing an issue with the automatic transmission (A/T) indicator light on your dashboard. The A/T indicator light is designed to alert you to problems with the transmission system. If the light is blinking, it may indicate that there is a problem with the transmission and it should be checked as soon as possible. There could be a number of reasons why the A/T indicator light is blinking on your Mitsubishi Spacegear. Some common causes include:
  1. Low transmission fluid level: If the transmission fluid level is low, it can cause the transmission to malfunction and the A/T indicator light to blink. Check the transmission fluid level and add more if necessary.
  2. Faulty transmission control module: The transmission control module is responsible for controlling the transmission. If it is not functioning properly, it can cause the A/T indicator light to blink.
  3. Wiring issues: If there are problems with the wiring in the transmission system, it can cause the A/T indicator light to blink.
I recommend having a mechanic diagnose the problem in order to determine the cause and recommend the appropriate repair. I hope this helps! Let me know if you have any other questions.
1/1/2023 11:52:49 PM • Mitsubishi... • Answered on Jan 01, 2023
Question about Mitsubishi D80
Mitsubishi D80not told how connectedNO PC toldno OS Told (windows or mac or what) XP to W8 is yes.no connections told.when did it last run googe, last week, last year or last decadereal model; this????CP-D80DW>> color printer?USB cable.? get the makers software , lost the CD of software ?windows XP and w7/8 is stated in your manualusing that?got front panel ALARM LED errors, page 20?read page 23, what to do before calling for help? do that?do the cleaning stepshttps://www.manualslib.com/manual/774805/Mitsubishi-Electric-Cp-D80dw.html?page=24&term=clean&selected=1#manualand up to w10 online support from maker. + OXS now.drivers seen here,the manual tells how to load that and connect USB last , never first, RTM read how to do that, and then test the printer with new ink.CP-D80DWhttps://mitsubishielectric-printing.com/en/downloads/drivers-tools
7/24/2022 8:39:22 PM • Mitsubishi... • Answered on Jul 24, 2022
I'm trying to find the engine number on my Mitsubishi magna wheres the location of it?
It is on the firewall on a metal plate. The firewall is the backwall of the car when you lift up your bonnet (hood). It should have your chassis number and engine number and paint code on it.
8/23/2019 9:03:35 PM • Mitsubishi... • Answered on Aug 23, 2019
How can i watch video through my sd card on mitsubishi nr-mz50 car dvd??
Mitsubishi Electric NR-MZ50 Car Navigation System $1800 !
WHAT CAR? and YEAR<, go to MFG. web sit and get the manual first, if LOST ! IT. What makes you think it can?> sure hope. WHA open glove box and RTM? yet, unstated car. car radio, head- in's/nAV are very dumbb(sic) as class of devices. they only allow a limited set of formats. you'r talking about movie file formats 100s, The movie file, formats to try are MP4 and MKV (most common) The manual Mz50. first. it will tell you what it supports, and no 2 car-heads work the same or have same limits, so that means RTM read the manual then do experiments. also some HEADs may have DRM rule limits. that car HEAD really is not a computer, so is off topic here. the MZ50 tuner can record to the SD card. why not just try it. find a small mp4 movie, and put it on the card, just 1 file and see if you can play it, but there are 100s of formats. talk to Mitsubishi dealer or try these https://fileinfo.com/filetypes/video It many do 1 or 2 but NEVER ALL formats.
7/1/2019 12:43:19 PM • Mitsubishi... • Answered on Jul 01, 2019
MITSUBISHI GLOVE COMPARTMENT LOCK
read the manual in the box, oops, can't down load it ? lost the key?
5/21/2019 6:42:49 PM • Mitsubishi... • Answered on May 21, 2019
Mitsubishi lancer 2.0 2009.shaking. I did wheel alignment & balancing and still the same. Took it for mechanic told the left shock had split oil. Advised to buy shock,tie rod ends & stabilizer links.
advised to buy [was those parts replaced ] and was damaged shock replaced in February or is it still damaged --your question is all over the place and confusing --------lets assume problem is now and alignment and balance was done recently bad shock -balljoints -upper or lower control arm bushings - tierods - steering rack- c/v axle --brakes any or all can cause shaking before throwing parts at it have the mechanic tell you reason part[s] need replacement and have them show you
11/6/2018 2:06:27 PM • Mitsubishi... • Answered on Nov 06, 2018
2answers
Getting speakers to work on Mitsubishi Medalion HD1080
get the latest drivers
11/15/2017 1:20:18 PM • Mitsubishi... • Answered on Nov 15, 2017
Antifreeze overflow tank empty
Hi Kristie,if your boyfriend can walk by your car and spell antifreeze,then you have a leak.Usually,it will be your water pump,you can put newspaper or whatever you can use under your car after you have driving it and wait awhile then check paper and see where it is wet to determine what is leaking,could also be a loose radiator hose which the clamp may just need tightening up,but first add some antifreeze to your over flow container,remove radiator cap after it cools down to see how much is in radiator,add if needed.Look around radiator area,it may be leaking.You can also jack it up to look.
7/29/2017 10:36:12 PM • Mitsubishi... • Answered on Jul 29, 2017
Have a 2001 Mitsubishi lancer oz rally drove it home put into park and shut it off car started to roll n is not turning on
I need you to clarify what the problem is, Park doesn't hold the car?
7/14/2017 7:08:11 PM • Mitsubishi... • Answered on Jul 14, 2017
0answers
5answers
Mitsubishi Diamond Pro 930SB limited by Vista
Go to settings and uncheck "hide frequencies my monitor does not support." now go back and see if 120h isn't an option.
5/2/2017 7:55:12 PM • Mitsubishi... • Answered on May 02, 2017
Mitsubishi Wd-82837 82" Inch 3d Full Hd 1080p Dlp Hdtv Home Cinema Television Logo
1 questions posted
Top Mitsubishi Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Computers & Internet
Most Popular Question
tv not turn blue welcome screen comes
  • Computers & Internet
