From the technical sheet hidden behind your control panel and online
here:
F7 Power to magnetron interrupted
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Check resistance of the magnetron thermostat.
4. Check the magnetron.
5. Check wiring to the 1100W inverter and control system. See “Checking
Inverters.”
6. Check operation of all interlock switches. Check door, hinge and cavity front alignment. Adjust as needed.
7. If switches operate correctly, replace 1100W inverter.
8. If problem persists, replace electronic control.
9. Plug in microwave oven or reconnect power.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
