20 Most Recent
Whirlpool LSW9750 Front Load Washer Questions & Answers
I have owned the Whirlpool Duet 9750 for 2 days.
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$##
9/30/2010 7:11:20 AM •
Whirlpool...
Answered
on Sep 30, 2010
Dryer Drum not rotating
If warm air is still coming from the unit, but the drum is not rotating, it sounds like your drive motor is fine, but your drive belt is broken. Depending on you dryer model, these can be fairly easy to check, or may take a little creativity to get the dryer apart. Knowing your dryer model number would go a long way towards assisting further.
5/7/2007 4:23:51 PM •
Whirlpool...
Answered
on May 07, 2007
How do i get a necklace stuck in holes of my Whirlpool thin twin washing machine?
It won't be easy - the necklace went through the hole so logically it should come back, unfortunately it is the nature of a necklace to be a random structure unless some tension is applied; the links or whatever are apt to go sideways and jam in the hole. In an extreme case the necklace could be knotted...
If it is knotted there is no chance of removal and the solution is either to dismantle the washer or to break the necklace.
Positioning the drum so the necklace is under tension under its own weight and with some jiggling and the application of lots of patience and some luck it should come back through the hole.
4/7/2024 3:13:20 AM •
Whirlpool...
Answered
on Apr 07, 2024
Whirlpool heavy duty commercial washer # cae2743800 will not start after coins inserted and start button held
Check the Coin Mechanism:
Ensure that the coin mechanism is functioning correctly. Sometimes, coins may get stuck or not register properly. Verify that the coin slots are clear and that the mechanism is engaging properly.
If there's an issue with the coin mechanism, it could prevent the washer from starting. You might need to clean or repair it.
Inspect the Wiring:
There should be a harness with two wires that go into the coin mechanism box. Check if these wires are intact and properly connected. If you find any damage or loose connections, consider repairing or replacing the wiring.
Bypass the Coin Mechanism:
If you suspect that the coin mechanism is causing the problem, you can bypass it temporarily.
Cut the wires going into the coin mechanism and insert a push button switch in the line. This will allow you to manually start the washer without relying on the coin mechanism.
If you're unsure how to do this, consider contacting a local repair shop for assistance.
Check for Other Issues:
Inspect other components such as the lid switch, control board, and start button. Any malfunction in these parts could prevent the washer from starting.
Make sure the washer is plugged in and that there are no tripped circuit breakers or blown fuses.
4/3/2024 3:28:33 AM •
Whirlpool...
Answered
on Apr 03, 2024
Whirlpool duet steam washer displaying F 20 error code during wash cycle. Water seems to be flowing just fine. I've unplugged it several times to clear the code but it's not working.
The F20 error code on a Whirlpool Duet Steam Washer typically indicates a water inlet problem. It means the washer is not getting enough water to continue the wash cycle. This can be due to several reasons, even if it seems like water is flowing fine at first glance. Here are steps you can take to troubleshoot and potentially resolve the issue:
- Check Water Supply Hoses:
- Ensure both the hot and cold water faucets are fully open.
- Inspect the water inlet hoses for kinks, bends, or twists that could restrict water flow. Straighten out any issues you find.
- Turn off the water supply, disconnect the hoses from the back of the washer, and check that the filter screens inside the water inlet valve are not clogged with debris. Clean them carefully if needed.
- Water Pressure:
- The washer requires a certain amount of water pressure to function correctly. Low household water pressure can lead to insufficient water flow to the washer. Make sure your home's water pressure is within the washer's required range.
- Check for Siphoning:
- Make sure the drain hose is correctly installed. The end of the hose should not be too far down the standpipe, and there should be an air gap to prevent siphoning.
- Inlet Valves:
- If the water hoses and screens are clear, there might be an issue with the water inlet valves themselves. They might not be opening fully due to electrical issues or mechanical failure.
- The inlet valves can be tested with a multimeter for continuity to ensure they are functioning correctly. If they lack continuity, they need to be replaced.
- Flow Meter:
- Some Whirlpool Duet models have a flow meter that measures the amount of water entering the washer. If this component malfunctions, it could mistakenly signal that there's not enough water, even when there is.
- Diagnosing a flow meter requires some technical knowledge and a service manual for your specific model.
- Pressure Switch:
- The washer uses a pressure switch to monitor the water level. If there's an issue with this switch or the hose connected to it, the washer might incorrectly interpret the problem as insufficient water flow.
- Check the pressure switch and the hose for any blockage, disconnection, or damage.
- Reset the Washer:
- Since unplugging the washer hasn't cleared the error, after checking the above, try to reset the control board by unplugging the washer for about 5 minutes, then plugging it back in.
If after trying these steps the F20 error persists, it may be time to consult the manual for more specific troubleshooting steps for your model or contact a professional appliance repair service. Sometimes, the problem could be related to the washer's electronic control board or other components that require professional diagnosis and repair.
3/10/2024 2:57:47 PM •
Whirlpool...
Answered
on Mar 10, 2024
Whirlpool Washer WFW94HEAW0 Front Load Washing Machine. Trapping Water in Unknown Area.
Stale smells come from not drying the front gasket trough just inside the door. Your bleach isn't cleaning that area. Use Tilex Mold spray on it. Clean and dry the door glass as well and leave the door open for a few hours after a wash or leave it open all the time. If it is dry, it can't smell.There will always be some water in the pump area, but if you remove the pump filter cover, that releases and water left behind.When you use bleach always do whites or your tea towels next. You can also dilute by adding a couple of jugs of water first.There is a trick to look for rattling items between the inner and outer drum. Put a good flashlight against the holes in the drum and you can see what is below without getting the glare from the drum.These websites give you a full parts schematic showing all the parts and their positions.
https://www.appliancepartspros.com/tub-basket-parts-for-whirlpool-wfw94heaw0.htmlWhirlpool Washer WFW94HEAW0 - OEM Parts & Repair Helppartselect.cahttps://www.partselect.caCanada Wide Same-Day Shipping For All In-Stock Parts. Shop Canadian And Avoid Customs ' 2 Million Parts Ready To Ship. OEM Parts & Accessories. One-Year Warranty. Money Back Guarantee. Free Repair Help & Videos. Types: Dishwasher Parts, Dryer Parts.
2/17/2024 9:23:21 AM •
Whirlpool...
Answered
on Feb 17, 2024
Whirlpool dishwasher will only drain
If the machine runs a while and then drains, it is like that there is a leak and the leak sensor has been activated. There is a tray between the base of the machine and the kitchen floor.
2/13/2024 11:52:14 PM •
Whirlpool...
Answered
on Feb 13, 2024
