20 Most Recent Marvin Quartz Radiant Heater Questions & Answers
2answers
Loud buzzing after heating up
the buzzing is normal.  there is an element inside the quartz tube much like a filament in a light bulb.  as this heats up it starts to move.  where you have electrical energy you also have magnetism produced. metal objects vibrate when they are in or within a magnetic field. the element is tungsten wire and vibrates off this magnetic field.
1/15/2024 3:51:48 PM • Marvin Quartz... • Answered on Jan 15, 2024
Locating replacement quartz bulbs for comfort zone heater
To locate replacement quartz bulbs for your Comfort Zone heater, you can try the following steps:
  1. Check the manual: Your Comfort Zone heater should have come with a manual that includes information on replacement parts, including the type of bulbs needed. Check the manual to see if it specifies the type of quartz bulbs that are compatible with your heater.
  2. Check the label: Look for a label or sticker on the heater that lists the make and model number. This information can help you find the correct replacement bulbs.
  3. Contact the manufacturer: Comfort Zone is the manufacturer of the heater, so you can try contacting their customer service department to ask for assistance in finding replacement bulbs. They may be able to provide you with the specific bulbs you need, or they may direct you to an authorized dealer or retailer.
  4. Search online: You can also search online for replacement quartz bulbs that are compatible with your Comfort Zone heater. Try searching for the make and model number of your heater, along with the keywords "quartz bulbs" or "replacement bulbs."
It's important to note that if the halogen lamp is also not coming on, there may be an issue with the heater's electrical system. In this case, it may be best to contact a professional electrician or appliance repair technician to diagnose and fix the issue.
2/26/2023 5:07:48 PM • Marvin Quartz... • Answered on Feb 26, 2023
2answers
Marvin 5460
Returned to home depot. Fan was broken.
11/12/2011 10:52:24 AM • Marvin Quartz... • Answered on Nov 12, 2011
Is it safe to plug a 1500 watt Marvin quartz
You had a low end cheap receptacle more than likely or possibly a loose wire on the receptacle. You should have #12 wire fed from a 20 amp breaker and a 20 amp spec grade receptacle.
I am a licensed electrician with 30 years experience. IBEW LU #479 Beaumont TX.
1/1/2011 3:32:31 PM • Marvin Quartz... • Answered on Jan 01, 2011
2answers
The heating elements are burnt out. where can I
try this web link look for quartz tubes.
http://www.infraredheaters.com/quartz1.htm
12/14/2010 1:11:02 PM • Marvin Quartz... • Answered on Dec 14, 2010
The heater turns on then stop working
The safety has tripped and these are not an economically viable repair
12/31/2009 7:35:28 AM • Marvin Quartz... • Answered on Dec 31, 2009
My Quartz heater is making a buzzing noise, what
The buzzing noise was coming from the back of hte unit on the lower left side. It may have been a "stuck" switch & tapping on the side seemed to fix it.
11/27/2009 7:56:48 PM • Marvin Quartz... • Answered on Nov 27, 2009
Element broken
call jhonstone supply or united refrigeration
12/19/2007 9:58:27 PM • Marvin Quartz... • Answered on Dec 19, 2007
Marvin heater 7260 light bulb burnt out
Marvin 7260 heater takes a T100W halogen bulb. Max 100 watt rating.
2/21/2019 10:02:31 PM • Marvin Heating &... • Answered on Feb 21, 2019
Does anyone know where I can get a 3 position rotary switch for a MarVin quartz heater?
Local heating and air supply house
11/7/2018 3:53:52 AM • Marvin Heating &... • Answered on Nov 07, 2018
Hi Marvin thank for the quick respond and i want to know where its location on the engine?
Hello, Norman - Please return to your earlier question: http://www.fixya.com/cars/t27109100-locate_crankshaft_position_sensor_honda Then, on that question and the answer from Marvin, click or tap on Comment and add your reply there, so that Marvin can see it and provide you with more information. On Fixya.com, the questions from a person and any answers are not all part of one thread. Best wishes.
10/9/2018 12:53:03 AM • Marvin Heating &... • Answered on Oct 09, 2018
I am trying to go online to call marvin online but dont know my miwam info
if you dont know noone else will
7/27/2017 5:06:57 PM • Marvin Heating &... • Answered on Jul 27, 2017
Heating & Cooling Logo
Popular Tags
20 questions posted
Top Marvin Heating & Cooling Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Marvin Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Marvin Heating & Cooling
Most Popular Question
locating replacement quartz bulbs
  • Heating & Cooling
