20 Most Recent
ATI RADEON X1300 PRO, (256 MB) PCI Express Graphic Card Questions & Answers
Maxi gamer 3 dfx
you might want to update the drivers and make sure you have good ventilation and air flow into case
Hey i have a ATI radeon X1300 series graphics card
Uninstall your graphics driver first and run driver cleaner in safe mode.
turn off your pc and
reseat your ATI x1300 and spot some dust on its gold interface to clean it. and reinstall gfx card ..
see if it helps
Dead video card in one computer and alive in another
What you can do is to try and reset the bios settings then try the card again...to do this you will need to look for the clear Setting Jumper on the motherboard..It should be right close to the battery there. move the jumper to the other pin and back..that should clear the bios settings and hopefully allows the computer to accept the card again.
google image search--clear bios jumper---to view how the jumper looks if u have not seen one
My HD 4850 fan is
Your heatsink fan on the graphic card is failing and the motor is going down hill, now saying it has completly stopped..,.. that means the fan motor is done for and need to be replaced to avoid further damage to your graphic card. Would reccommend you not using your graphic card until a new heatsink fan is replaced otherwise you can fry your GPU and suffer a complete loss.
My graphics card will not
How did you get your drivers and graphics? Did you install the whole package? What is the Asus model #? How much Ram do you have? I'm going to do a little research but let me know what you have.
Dave
HIS radeon HD 6750
Are you certain that your mainboard is PCIE 2.1 and not PCIE 2.0?
PCIE 2.1 cards like yours will not work on a 2.0 mainboard (2.0 cards will work on a 2.1 board, however) If this is the case, you will need to get a compatible card.If this isn't the case, have you tried this card in a different PC? It could also be that the card has a problem.The last possibility is that there are power issues. A couple of possibilities:
- An external power connector (6-pin PCIE direct power to the video card) is unplugged. Check and re-test.
- Your power supply (PSU) doesn't provide enough power to your graphics card & the rest of your system. Check your PSU's specs against the specs for your card. HIS recommends a minimum 450W PSU, and I would recommend a good quality Antec, Corsair, or PC Power and Cooling or Cooler Master product in the 500W range for this card.
- You got a bad card, or else it shorted out, etc. during setup or installation.
Gigabyte vga card d33006
your card is the gigabyte GV-RX195P256D-RH and you can download the drivers from here https://www.gigabyte.com/us/Graphics-Card/GV-RX195P256D-RH#support-dl-driver-vgadriver
