20 Most Recent
Maxtor DiamondMax 80 (96147H6) 61.4 GB Hard Drive Questions & Answers
Hard drive not readable
You can try it on another computer but I expect you will need data recovery help. I can suggest http://FreeDataRecovery.us
8/24/2012 8:26:54 PM •
Maxtor...
Answered
on Aug 24, 2012
6E040lo error code CA699178
are you sure this is the error code ca699178 ?click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
hope this helps you
3/24/2012 6:18:11 PM •
Maxtor...
Answered
on Mar 24, 2012
Hard drive clicking
your las hope is to replace the Pcb Controller with a working and exact same one ,
2/9/2012 1:45:01 AM •
Maxtor...
Answered
on Feb 09, 2012
Maxtor External Hard Drive No Power
I assume it is a USB connection? Does it also have a power adaptor or a USB dongle that has 2 USB connectors? If you cannot get it to power up, the only other option to retrieve your data is to take the HD out of the case and connect it to a PC or laptop using a SSD or SATA to USB adapter and see if you can get the PC to recognize it.
