20 Most Recent
Infinity 1250w Car Subwoofer Questions & Answers
How tw install
Hook you Line Out from Car Stereo to the Line In of your Subs. Power your subs with the red (+) wire going to the battery and th black (-) wired to the chassis.
How do i get the best sound from my infinity 1250w subwoofers
Make sure the ohm's are the same on all your speakers and amp.
You amp watt should be equal or higher then your speakers total amps.
You base box should be completely air tight, and have about 1/2 of the box stuffed with cotton.
Make sure you use a good thick speaker cables to connect from the amp to the speakers.
and finally, make sure your trunk seals tight and wont rattle... cause nothing sounds worse then someone pulling next to you and all you hear is a buzzing sound from the trunk rattling... Also... sell the infinity's and get something like memphis, or panasonics. :P
2 sets of pos. and negs. on 10" infinity reference 1052w
This means you have a dual voice coil sub. It is probably a dual 4 ohm voice coil. If you hook up the left channel to one input and the right to the other you can safely push the sub but the amp will be running at a lower efficency. In other words it isn't the best amp for the job because it can't push max power to a dual voice coil speaker but it will work.
I have a cracked sub for a car system 12''
you would be amazed what a little clear silicone will do make sure you apply to both sides using a popcicle stick spreads it on nicely or try using a hot glue stick try it it will work
Inifinity 1252w subwoofer
this is probably due to the box they are in. it seams that your box is tuned to a lower freq then the bass hits that are popping. message me with the box dimensions and the speaker parameters
My infinity is blown
You see that black round on the middle, ussually they put name print (infinity). You have to take that to access the voice coil. You can use a soldering iron to heat up the adhesive but make sure you dont burn it. Use a low wattage soldering iron.
What is the wiring schematics for an Infinity Gold Amplifier 56007499?
hi,
if thats a dodge this might be it..
Re: Infinity Gold AMP Wire Diagram
Well I don't particularly care for
Haynes manuals, but my FSM's did not have anything either. I found this in thejeep cherokee haynes manual and it says that it is for 97 and later models but see if it is close. it looks like there are 2 harnesses so I will list them seperately:
Hartness 1:
[7] Left Soundbar Speaker (+) BR/YL
[8] Left Soundbar Speaker (-) BR/LB
[5] Left Front Door Spkr (+) DG
[1] Left Front Door Spkr (-) BR/RD
[9] Right Soundbar Speaker (+) DB/WT
[3] Right Soundbar Speaker (-) DB/OR
[6] Right Front Door Spkr (+) VT
[2] Right Front Door Spkr (-) DB/RD
[4] Power Amp Relay Feed DG/RD
Harness 2:
[05] Right Soundbar Spkr (+) TN/RD
[13] Right Soundbar Spkr (-) TN/BK
[06] Left Soundbar Spkr (+) WT/TN
[14] Left Soundbar Spkr (-) WT/BK
[11] Passenger Door Spkr (+) LB/RD
[10] Passenger Door Spkr (-) LB/BK
[04] Drivers Door Spkr (+) DG
[12] Drivers Door Spkr (-) LG/RD
[01] Power Amp Feed
[02] Power Amp Feed
[07] Power Amp Ground
[08] Power Amp Ground
The tweeters run in parallel off of the door speakers.... If I can help any more let me know.
-Mike.
https://forums.off-road.com/jeep-mid-sized/105694-infinity-gold-amp-wire-diagram.html
