20 Most Recent
Pioneer XM2go Inno Satellite Radio Receiver Questions & Answers
Pioneer Inno FM modulator
Make sure it is docked in the docking cradle for the car. The option will not come up if the unit is not in the docking cradle.
I would like to know
Hi, it is not possible to reduce the sound volume less than the original factory settings except you want to change the whole control board of the receiver where the sound i.c is located and that will be as good as getting a brand new receiver...
When plugging in my inno
Replace the fuse, test the radio, then repair you inno prongs before inserting into the cigarette lighter again.
I installed a sony fm/am
do you hear low volume on sat radio or no volume at all.Is it new installation.If yes ,then recheck the connections.But if its old,previously installed long back.Then was it working before or not worked at all.
check out.keep updated.,thanks.
Pioneer inno will not recive xm singal
Are you still having this problem? Sounds like you just aren't getting a good signal. Antenna is not properly mounted, not getting good singal.
Or, the antenna and/or cable is damaged.
PIONEER INNO
Mine didn't work out of the box either -- but i discovered if i warmed the remote up ---it works fine. I put it in front of a heater vent till it gets warm then it works great --- as long as it doesn't cool off.
Volume control
Remove the back battery cover only. Turn unit on. Insert a tiny paperclip thru the tiny 'reset' hole on the back of the unit inside the battery compartment. OK?
