20 Most Recent
Pioneer PDP-425CMX 42 in. Plasma Television Questions & Answers
Only One HDMI Input Works
with hdmi plugged in take power cable out of apple tv ,put power plug back in then look to see if you have a signal....
2/5/2018 8:20:14 PM •
Pioneer...
Answered
on Feb 05, 2018
My tv does not have
There are adaptors available to convert HDMI signal to other standards. You will lose quality in picture and sound but you can get HDMI to RCA converter. If your TV has a DVI is still a digital input so will yield better quality.
1/14/2018 8:05:05 AM •
Pioneer...
Answered
on Jan 14, 2018
The tv has power .the red light is on ,but when it
Tod,
The little plastic button you are referring to is the IR receiver for the Remote. When the TV turns itself off, are there any flashing lights on the front or rear of the unit. Look through the vents in the rear for any flashing lights or try tuning the tv on in a dark room and see if any lights flash and reflect off of walls. If there are flashing lights tell me how many flashes and what color and I will try to look them up in the manual.
11/11/2010 4:02:16 PM •
Pioneer...
Answered
on Nov 11, 2010
The signal appears to buffer on some channels
When you are seeing buffering only on some channels then that is your cable provider or satellite. Nothing to do with your tv.If it were buffering on all then you can suspect something in the reciever section being annoying.
4/23/2010 2:44:42 AM •
Pioneer...
Answered
on Apr 23, 2010
Pioneer plasma tv has vertical white line
Hi my name is Roety,
I can help you with your issue ,
If the line is present on all inputs, and effects the menu the panel (screen ) is bad.
The cost of a new panel is probably more than a new Tv.
Try reseating the ribbon cables before trashing the TV
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks I’m happy to help further over the phone at
https://www.6ya.com/expert/eric_ab7c09ec01841771
10/19/2009 3:03:44 AM •
Pioneer...
Answered
on Oct 19, 2009
Pioneer plasma 42 inch tv
There should be a power button on the bottom of the panel that has to be depressed for the television to power on. It is the main power supply button and without it there is no power going into the TV.
8/18/2009 12:46:56 PM •
Pioneer...
Answered
on Aug 18, 2009
Cables
Greetings 4mother,
It would really depend on what type of hook up you are using. Most of the time a plasma television would be hooked up with either and HDMI or component cables. Your local store should be able to make a solid recommendation based on the items hooked up to your television such as cable or satellite box, dvd player, etc.
I hope this helps.
Thank you,
Dorothy
Go Ahead. Use Us.
5/14/2009 6:55:36 AM •
Pioneer...
Answered
on May 14, 2009
Dpo adjustment
Press the menu key on the remote on on the tv itself.
Look for the menu option that says "setup" or Video Adjust, or something of the like. It should give you options like: color, tint, sharpness, etc.
Just browse through the menu to see how yours is setup.
Hope this helps.
enov8
3/7/2009 7:51:11 PM •
Pioneer...
Answered
on Mar 07, 2009
Pioneer PDP-425CMX 42" Plasma Tv
Try the scan PCBs that run down the side and the connectors that hook them up to the rest of the system. That would be my first place to start.
Unfortunately I don't have service manuals for non-european models. What is the date of manufacture?
1/12/2008 5:06:36 PM •
Pioneer...
Answered
on Jan 12, 2008
My pioneer amp 820w blinking blue why?
The blue blinking light on your Pioneer amp could indicate a number of issues. One possible reason is that the amp is in "standby" mode, which means that it is not currently receiving any audio signals. Another possibility is that the amp is experiencing an error or malfunction.
To get a better understanding of the issue, I would recommend checking the user manual for your Pioneer amp. If you don't have the manual, you can try searching for it online using the model number of your amp. You can also try resetting the amp by unplugging it from the power source for a few minutes and then plugging it back in. If the problem persists, it may be time to take your amp to a professional for repair.
11/20/2023 8:53:25 PM •
Pioneer...
Answered
on Nov 20, 2023
