20 Most Recent
3M Projector lamp Projector Lamp Questions & Answers
3m mp8670 projector will turn off
the mainboard is fault
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Proyector 3m mp 8670
the lamp is ok
the lcd panels were fault
you need a new one
USD160
Have a nice day!
Lampdeng Limited
Jerry
Green screen
the lcd panel is LCX016 usd 80 Have a nice day! We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. Lampdeng Limited Jerry
InFocus LP630
get it from projectordoctor.com or from infocus. do not get cheap replacements. you get what you pay for.
Green Screen
Replace your RGB Cable. If the cord is crinkled an internal wire may be broken or if pin 7 is missing or bent, the green ground can be lost. It is not a problem with the bulb. The RGB cable can be purchased for much less than 300 pounds.
Projector
Go into the projector menu, OPTION and then select LAMP TIME.
Blur Image
Hi there
If it is a DLP Projector it could be the Packlight Pipe Module that needs repairs.
Basically this part has 4 small mirrors facing each other and this normally happens when one of the mirrors come loose.
Very cheap to repair
3m projector mp 8020
hey,
i think you problem is that the s-vhs output on the labtop is not enabled.
My old labtop needed restart with the projector on, and also had a switch to set in the bios.
So take a look in you manual for the labtop.
Have you tryed the projector on a dvd player or something like that, just to bee sure the projector works fine?
best regards michael
miguelovitch amplifiers
