20 Most Recent
AEG D4101-4 Electric Double Oven Questions & Answers
AEG D8100-1ME oven turns off
The service person who "by-passed 2 thermostats" should be reported to your local energy provider as this is unsafe, may cause a fire and is against Australian laws. I suspect he may not even be properly licensed or qualified. I would strongly suggest turning the unit off at the main switch board until a properly qualified and licensed service tech can look at the unit. With regards to "Home handy-man" wiring (finding a service manual and doing your own repairs) I would strongly recommend against it. Australian Standards are written very specifically to protect the end user (you) of any electrical equipment in Australia. This includes cable sizes & ratings, thermostat settings, the whole ball of wax. Have a go yourself and you are taking not only your own life, but everyone who ever touches that unit into your own hands.
My AEG competence oven is
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
How to set the time on a B7500M AEG oven
To set the time on an AEG B7500M oven, follow these steps:
- Press the "Clock" button on the control panel. The display will show the current time.
- Press the "Hour" button to set the hour. Use the "Plus" and "Minus" buttons to adjust the hour.
- Press the "Minute" button to set the minute. Use the "Plus" and "Minus" buttons to adjust the minute.
- Press the "Clock" button again to confirm the time and exit the time-setting mode.
Note: If the oven is in the process of cooking or baking, you will not be able to set the time until the cooking or baking process is complete.
3/6/2024 2:40:18 PM •
AEG Ovens
Answered
on Mar 06, 2024
AEG oven tripping rcd at random points?
An RCD tripping points to an earth leak because that is what they are designed to do.
Check the wiring and pay special attention to the insulation.
10/8/2023 7:36:45 AM •
AEG Ovens
Answered
on Oct 08, 2023
F19 error code AEG Double fan oven please help Keeps tripping the RCD
The F19 error code on an AEG double fan oven typically indicates a problem with the oven's electronic control board. This could be caused by a malfunctioning component on the control board, a loose connection, or a problem with the wiring.
If your AEG double fan oven is displaying the F19 error code and tripping the RCD (Residual Current Device), it is recommended to unplug the oven and stop using it until the problem can be resolved. Here are a few steps you can try to troubleshoot the problem:
- Check the wiring: Make sure all the wires and connections are secure and in good condition. If any of the wires are frayed or damaged, they may need to be replaced.
- Check the control board: Inspect the control board for any visible signs of damage, such as burnt components or loose connections. If you find any issues with the control board, it may need to be replaced.
- Check for debris: Make sure there is no debris or foreign objects inside the oven that could be causing a problem with the control board.
If you are unable to determine the cause of the problem or fix it yourself, it is recommended to have the oven inspected by a qualified technician. They will be able to diagnose the problem and recommend the appropriate repairs.
12/25/2022 8:45:48 AM •
AEG Ovens
Answered
on Dec 25, 2022
Aeg oven taking over 25 minutes just to heat
You can tell if the fan is working, you will hear and see it.
If the element was bad, it wouldn't get hot at all.
If the thermostat was faulty, it usually goes short circuit and makes the element glow in time because it won't regulate the heat.
There are a couple of possibilities left;
Wrong element, too low a wattage.
Bad connection to the element.
10/26/2021 7:13:00 AM •
AEG Ovens
Answered
on Oct 26, 2021
