20 Most Recent
AEG B3101-4 Electric Single Oven Questions & Answers
Went to switch oven on
HI, Sounds like your from the UK
If you are referring to a trip switch as being equivalent to an American circuit breaker. (Electrical safety device designed to shut down power to an electrical appliance). Then we are on the same page.
Do the following diagnostic procedure:
1 SHUT DOWN THE POWER SUPPLY TO THE OVEN. I.E. THE TRIP SWITCH/CIRCUIT BREAKER.
2 Open the oven door and look very carefully with a flashlight at
the heating element. Look at the the entire element. If
it blew (similar to when a light bulb blows) you will
find white
powder around the hole in it or it will be completely broken, or have
bubbles in it. Some indication like that. If so it has failed and
must be replaced. It is probably tripping the switch because it is shorting out somewhere. There is also the possibility that the internal wiring connectors to where the element is mounted into the oven walls is broken off and short circuiting against the oven chassis (walls). That being the case, it may be just a wiring repair in which you install new appropriate electrical contacts and re-connect the element.
Hope this helps,
Happy New Year,
Mark
I have an AEG B3101-4
first check the power to the unit itself, to be sure the house power is on , if the unit is totally dead,, then remove the back to locate a fuse that will be just next to the incoming line, check both of these items with a volt meter if you feel thats something you can do.
My AEG B3191-4 oven works for about 30 mins, then
Your cooling fan may not be working. either the fan is faulty or its controling device is not switching it on it also allows the fan to run on after the oven has been turned off. its located in the wiring loom behind the switches. part 899661926761-1 costs £26
AEG B3101-4
do not shoot the
messenger here but I have read that people took a hair
dryer to melt the glue that is
possible culprit to why
you cannot get this from the fascia. I know there is not screws involved so do not be fooled into any answer the involved screws, its got to be some type of glue holding it.
Thanks I hope this helps please do click the accept button for my efforts. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
My AEG B3101-4 oven works for about 30 mins, then
It is a safety thermostat that is cutting the oven off, due to overheating.
It could be that the external cooling fan is not working, or the cut out itself is faulty.
Check to see if you can hear the fan working.
This is usually located on the top of the oven , at the rear of the oven, on the top .
Hope this helps.
Fan won't knock off.
Hi.
the most likely cause is a failure in the cooling fan cut out switch.
It is located underneath the top cover of the oven.
replacement is fairly straight forward.
I have attached a photo so you know what it looks like.
I can supply you one if you have trouble sourcing one.
Just email me on
[email protected]Regards
Aardvark repairs
