20 Most Recent
Eiki LC-SB20 Projector Multimedia Projector Questions & Answers
Projector is not project data
Try to lower the output resolution of your laptop for external display to
800 x 600, which is the native resolution for your SB20
ALL OF MY MOVIES LOOK ON BLUE COLOR
1.leaking polarised glass parts in the blue channel.
2. worst case a leaking lcd panel, impossible and very expensive to replace, you will need a complete optical block
How do i replace the ballast?
no indicator lights,means that is no electric current is found in Mainboard , the mainboard or main power is defective
maybe the ballast is work well ,is ok.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD, motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail:
[email protected]
Skype: lampdeng.com
YM:
[email protected]
http://facebook.com/lampdeng
http://www.lampdeng.com
turn your contrast down to only 50% and same with your brightness.
Won't power up
The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service.
A copy of your manual is available at
http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf
Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
Black and white projection
Hi there
First try another cable from the PC to the Projector.
The VGA / RGB Cable used from your PC to the Projector has a couple of very thin copper wires on the inside and they easily get damaged.
If this doesn't help then you should try another PC.
If that works then you'll know that it is the PC's card that is faulty.
If it doesn't work you'll have to get the Mainboard repaired or replaced , because the inputs on the Projector lies within the Mainboard.
Must warn you that a Mainboard replacement is a bit on the expensive side.
Cooled down
Hello again gabzky,
My apologies for getting back to you a bit late. I understand that you followed the manual but was not able to resolve your problem.
There is something else you can try, hard reset the unit. At the back of your LC-SB20 Projector between DVI-I and Service port, above and to the left of the computer/component in is a small reset button. You may need to use a ballpen to depress the button.
You have to press this with the power on.
Cheers and keeping my fingers crossed for you.
