20 Most Recent
AEG MC143EUX 750 Watts Microwave Oven Questions & Answers
Microwwave
Could you be more specific as to what it's doing and not doing and when? Thanks.
I have a AEG Competence
The thermal cut out switch needs re setting
Unplug the machine . Remove the 6 screws from the top of the machine and remove the top cover .
the thermal cut out switch is located on top of the heat exchanger which is a large brass cylinder in the middle of the machine as you look down. The thermal cut out is round black plastic with two electrical plugs on top towards the front of the heat exchanger.
there is a button on top of the cutout which can be pressed. If the button clicks then that was your problem.
Mcc 3880e m
There is no microwave, so I suggest to check all HV components (magnetron, HV reactifier diode, HV fuse or protect diode, HV capacitor and eventually transformer).
Dado
