20 Most Recent
AEG MCD3534EM Stainless Steel 900 Watts Microwave Oven Questions & Answers
I have a AEG Competence
The thermal cut out switch needs re setting
Unplug the machine . Remove the 6 screws from the top of the machine and remove the top cover .
the thermal cut out switch is located on top of the heat exchanger which is a large brass cylinder in the middle of the machine as you look down. The thermal cut out is round black plastic with two electrical plugs on top towards the front of the heat exchanger.
there is a button on top of the cutout which can be pressed. If the button clicks then that was your problem.
Mcc 3880e m
There is no microwave, so I suggest to check all HV components (magnetron, HV reactifier diode, HV fuse or protect diode, HV capacitor and eventually transformer).
Dado
