20 Most Recent Nikon Coolpix 5400 Digital Camera Questions & Answers
NIkon cool pix 5400 will not turn on. Battery is fully charged.
A couple of possibilities. The battery is bad and not accepting a charge. Replace the battery. The battery terminals are dirty. Using cotton swab and some isopropyl alcohol, clean then fully dry the metal contacts on the battery and inside the battery compartment. Before turning it back on, be sure everything is fully dry.
8/2/2016 5:33:57 PM • Nikon Coolpix... • Answered on Aug 02, 2016
Why dose my camera say out of memory when I have new memory card?
Could be a faulty card or the contacts that read the card are dirty. Try the card in another machine to rule out card error.
9/15/2014 4:06:23 AM • Nikon Coolpix... • Answered on Sep 15, 2014
Flash replace damaged
ebay..... look for a spares/repair..... if its worth it
5/25/2014 5:41:42 AM • Nikon Coolpix... • Answered on May 25, 2014
I bought a used nikon coolpix and added an 8gb card for it but it says there is no memory available even though i already formatted it
Try reformatting the memory card using the camera go to the camera's Menu and select format memory card.
12/13/2012 1:01:50 AM • Nikon Coolpix... • Answered on Dec 13, 2012
2answers
I have a Nikon E5400, ver 1.3. I bought a 4GB
I'm assuming you tried to format the card in the camera. If there's a firmware update for your camera, by all means, get it.
11/3/2012 5:27:03 AM • Nikon Coolpix... • Answered on Nov 03, 2012
I cant record video why?
The Nikon should have a Movie mode, select this mode to record a video.The problem maybe a slow SD memory card.Use a SD memory card that has a Class 8 or 10 speed.
6/16/2012 8:03:48 AM • Nikon Coolpix... • Answered on Jun 16, 2012
How do i turn on the timer
Press the AF button (also marked with a one-handed clock) until the one-handed clock symbol appears on the screen.Full details are in the "Self-Timer Mode" section of the manual (page 35 in my copy). If you need a manual you may download a copy here.
5/6/2012 6:19:37 PM • Nikon Coolpix... • Answered on May 06, 2012
New computer w/windows 7. reinstalled nikon5400.
You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
You might want to consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
4/11/2011 5:18:30 PM • Nikon Coolpix... • Answered on Apr 11, 2011
When I connect the USB to my computer it states
Try NOT connecting your camera to your computer.
4/6/2011 8:53:03 PM • Nikon Coolpix... • Answered on Apr 06, 2011
I started using my old Nikon CP5400. I connected
Consider NOT connecting your camera to your computer.
4/1/2011 5:04:51 PM • Nikon Coolpix... • Answered on Apr 01, 2011
When using my Nikon CP 5400 - the videos are not
This sounds like an issue due to low light. The card will not cause the video or pictures to be grainy, but high ISO settings (used to compensate for low light) will. In low light, auto-focus has a hard time and usually a camera won't take a shot unless focus lock occurs.
Assuming you were shooting in a low-light situation, the solution is to add more lighting to the scene.
Note that the flash on your camera is only good for a distance of about 10 feet.
3/1/2011 10:50:49 PM • Nikon Coolpix... • Answered on Mar 01, 2011
Lense has locked in extended
I guess your battery is too low. Take the battery out and charge it, then put it back into the camera.
If the problem still exists, you could try to force it back into the camera (Caution: The mechanics could brake down! I did this once with my Sony Digital Camera and after it worked fine, but I don't know if it would cause serious damage to the Nikon).
2/28/2011 5:56:37 PM • Nikon Coolpix... • Answered on Feb 28, 2011
2answers
Lense has locked in an extended position. Coolpix
I Hope the steps below should be helpful in fixing your camera issue.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Regards,
Ron
2/28/2011 5:20:49 PM • Nikon Coolpix... • Answered on Feb 28, 2011
Camera powers down after about 30 seconds.
This sounds like the battery is no longer keeping a charge or working properly. I suggest you purchase another battery and see if this fixes your problem. These cameras also worked on a disposable battery called the 2CR5 which should be available at your local walgreens, cvs, duane reade. If this does not solve the problem then you will have to take or ship to local service center. I use photo tech in New York; www.phototech.com
2/26/2011 7:10:57 PM • Nikon Coolpix... • Answered on Feb 26, 2011
What to do if I have a problem with lens, they can
Hi, the lens unit are dirty or damaged ,best way contact Nikon service.
Regrds
2/26/2011 4:47:14 PM • Nikon Coolpix... • Answered on Feb 26, 2011
White lines in pictures
clean the lens if not success then its a camera CCD problem.
1/6/2011 7:31:51 PM • Nikon Coolpix... • Answered on Jan 06, 2011
Nikon Coolpix 5400 Digital Camera Logo
104 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
turn timer
  • Cameras
