20 Most Recent Maytag 22 cu. ft. Bottom Freezer Refrigerator MBL2262HES / MBR2262HES Questions & Answers
Why is there a layer of ice on the floor of the bottom freezer of my refrigerator?
The water most likely is coming from a defrost drain blockage. Unplug and remove the rear panel inside the back wall of the freezer. See panel location #4 in the photo=> HERE You will need to get that panel out of the way to see and clean out the defrost drain. Click Here=>Leaking Refrigerators I am here should have questions, Thanks John Tripp Appliance 911
7/23/2014 5:20:05 AM • Maytag 22 cu.... • Answered on Jul 23, 2014
I have a 5yr old
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
6/30/2011 10:40:54 PM • Maytag 22 cu.... • Answered on Jun 30, 2011
How to adjust my fridge
If you take off the bottom grill you will see the ajustment screws by the wheels. Hope you found this helpful and thank you for using Fix ya.
6/22/2011 11:39:33 PM • Maytag 22 cu.... • Answered on Jun 22, 2011
The temperature is staying constant at 51 degrees
Your fridge is probably suffering from a fan failure or defrost circuit failure. One (or possibly more) of the following components has failed: 1) the defrost terminator or sensor, 2) the defrost heating element or 3) the defrost controller / timer. Items 1 & 2 will be found in the freezer compartment - behind the back wall. The 3rd item can often be found in the toe space at the bottom of the fridge - behind a kick plate. The fan I mentioned is located in the freezer - in the cooling coil compartment. It is used to pull air over the coil to cool it and circulate it in the freezer - and direct a portion of it into the fresh food compartment as well. If it has failed, temperatures in both the freezer and fresh food compartment will rise.
Before we go further - check and clean the condenser coils on the bottom of the fridge with a vacuum. They may be clogged with dust and dirt. Listen for the compressor and fan - are they running? Since everything inside the fridge is warm and getting warmer - the compressor should be running to try to cool it. If left to run like this for a long time however, can cause the compressor to fail. This is usually a deal breaker for repair due to cost. If the fan or compressor isn't running - you should probably call a repair person.
If you don't know how to work with electrical meters and tools or are not comfortable working in tight spaces (back wall of the freezer) with live electric parts, you should call a repair person. Also, refrigerants are under pressure and are very dangerous. If allowed to escape from the tubing, coils, etc. there is a very real danger of instant frostbite if it comes in contact with your skin. You can be blinded if it sprays into your eyes. These reasons make me believe that this is a complicated DIY type job and really isn't a good one for a beginner or even an intermediate to attempt. On the plus side, parts are relatively inexpensive, and a qualified person should be able to quickly diagnose the problem. Labor rates and parts markups can bring this repair up into $200 and up range, however.
If you can't swing that amount of money right now, unplug the fridge, empty the freezer (& fridge if needed) and completely defrost the the freezer. If you access the freezer coil behind the inside back wall, you can greatly accelerate the defrost process by leaving the freezer door open - or even faster still by directing a blow dryer at it. Once all the frost is melted, plug the fridge back in, allow to get cold & reload the freezer. Depending on how humid it is in your kitchen, you can put off the repair at least a month or more. If after defrosting it still fails to cool down, the freezer compartment fan described in the top paragraph has probably failed. Ideal temps for fresh food is about 34-36 degrees and the freezer is about -5 to 0 F.
If / when you do finally call, for service, have the freezer emptied & defrosted already - will save the defrost time by the repair person.
If you are comfortable performing this work, let me know and I'll get you more information. I hope this was helpful and good luck. Please rate my reply - thank you.
5/3/2011 10:06:04 PM • Maytag 22 cu.... • Answered on May 03, 2011
Refrig is not staying cold, power works, light on,
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
4/17/2011 7:41:46 PM • Maytag 22 cu.... • Answered on Apr 17, 2011
I have a french door
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
4/3/2011 5:42:46 PM • Maytag 22 cu.... • Answered on Apr 03, 2011
AFTER AN ELECTRIAL SURGE, THE CONTROL PANEL'S
Hello
You can reset by unplugging fridge for 3 min then plug it back in.It may be looking for degrees in Celsius or degrees in Fahrenheit.
Have you set that yet.
3/28/2011 4:06:38 PM • Maytag 22 cu.... • Answered on Mar 28, 2011
The freezer is not keeping
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
10/8/2010 2:40:47 AM • Maytag 22 cu.... • Answered on Oct 08, 2010
Fridge not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
7/12/2010 3:58:25 PM • Maytag 22 cu.... • Answered on Jul 12, 2010
On June 5 had ice and frost buildup in the back of
Have you cleaned to condensor coil on the back of the box at the bottom where the compressor is at take a vacuum cleaner and clean the coils see if this helps sounds like you have an airflow problem.
6/29/2010 6:00:38 PM • Maytag 22 cu.... • Answered on Jun 29, 2010
Freezer is not keeping food frozen
the problem just might be honey bees they buzz alot and if the infestation is to out of control it may cause the fridge to thaw the quick fix is to find the queen and remove it the others will follow i might add you may need protective gear for such a heroic feat
4/3/2010 11:41:22 AM • Maytag 22 cu.... • Answered on Apr 03, 2010
2answers
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
6/28/2009 5:17:17 PM • Maytag 22 cu.... • Answered on Jun 28, 2009
OLDER GE SIDE BY SIDE REFRIGERTOR MOVED OUT TO
Turn off the icemaker.
6/8/2009 2:31:37 PM • Maytag 22 cu.... • Answered on Jun 08, 2009
How do you install maytag "mbb1954g" ice maker plastic water line connection to the freezer?
To connect the water supply using a plastic hose kit to the MBB1954G UNIT, you can follow these steps: Turn off the water supply valve under the sink. Remove the old hose from the water supply valve and the back of the refrigerator. Attach the new plastic hose to the water supply valve and the back of the refrigerator. Make sure the hose is not kinked or twisted. Tighten the fittings with an adjustable wrench. Turn on the water supply valve and check for leaks. Here is a video tutorial that demonstrates how to install a water line to an ice maker or refrigerator using a 5 foot hose with 1/4 inch compression fittings. INSTALLING ICE MAKER / REFRIGERATOR WATER LINE - using 1/4" compression hose (youtube.com)
2/15/2024 9:40:38 PM • Maytag... • Answered on Feb 15, 2024
Maytag 2 door fridge has only water for ice cubes. Is there a water filter for the ice?
you can add water filter. It is installed on supply line. go to Home Depot and pick up a refrigerator water filter kit with accessories.
10/19/2023 1:58:54 PM • Maytag... • Answered on Oct 19, 2023
Maytag 22 cu. ft. Bottom Freezer Refrigerator MBL2262HES / MBR2262HES Logo
34 questions posted
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
adjust fridge
  • Refrigerators
