20 Most Recent Maytag MTB2191AR Top Freezer Refrigerator Questions & Answers
Yes, Defrosting it would work and making sure the vents in the freezer is not blocked with freezer foods.
Maytag MTB2191AR... | Answered on Jul 03, 2011
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Maytag MTB2191AR... | Answered on Jan 06, 2011
Yes the fan motor can be the problem but I would disconnect the wiring from fan and use a voltage meter to see if the problem is coming from mother board or like some models the fan also turns off when freezer door is open, meaning bad door switch. But must not assume at this point. Give me a few moments and I will send you detailed information, Sea Breeze Can you confirm that your model number is the MTB1911AR? Sounds alo like a series of events are taking place so it is a tossup of the fan or a defrost problem but if the fan stops it will cause the evaporator to freeze over and the compressor will struggle to pump the -20 degree freon. So unplug until we can diagnose the problem directly. Sea Breeze
Maytag MTB2191AR... | Answered on Aug 08, 2010
defrost timer broke, needs to be replaced
Maytag MTB2191AR... | Answered on Mar 30, 2010
Slide the frig out, (Unplug Frig. first) remove the cover so you can see the condenser, beside the condenser there is a switch that has to be carefully removed w/(fasteners) Take to your nearest appliance store, last time I did this it was like $52.00. Carefully plug-in, take not were the wiring goes usually they only fit just one way. reassemble cover, plug-in you should hear it kick on, good luck.
Maytag... | Answered on Oct 01, 2019
If you go to https://www.filtersfast.com/Maytag-Refrigerator-Water-Filters-cat.asp
It will show you styles of Maytag Refrigerators. If you click on the one that matches your style, it will show you possible areas the filter is located. You can then look in those areas. Once you locate it, then you can then identify your filter part # and replace if needed. You can also go to Maytags website and look up your model and find the manual. The manual will likely tell you where the filter is and what the part number is.
Maytag... | Answered on Sep 17, 2019
Is icemaker switched on. Usually located near icemaker/ Or maybe faulty switch
PLEASE CHECK THE CONNECTION CAREFULLY AND THEREAFTER IF NOT WORK THEN CONTACT TO WELL MACHANIC.
Maytag... | Answered on Sep 15, 2019
Maytag MTB2191AR Top Freezer Refrigerator Logo
14 questions posted
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
fan isnt working in freezer emptied
  • Refrigerators
